Like Tree34Likes
Old 09-20-2016, 10:27 AM   #1681
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
I was going to suggest stiffer side springs. You can also move the wing forward and down.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 09-21-2016, 09:21 PM   #1682
Trader Rating: 43 (100%+)
What motors are a good choice for F1? I've been using LRP X20, but they seem very torquey, leading to wheelspin off corners. Are there motors which are milder in their delivery at lower rpm?
I have played with timing, ESC settings and radio settings, some of which helped a little.
matrix101 is offline   Reply With Quote
Old 09-21-2016, 09:27 PM   #1683
wkderf's Avatar
Trader Rating: 18 (100%+)
The popular motor at my local track for F1 has been the Motiv M-Code. While its expensive, its power curve is perfect for F1, and is top quality and hand built. No complaints from amy of the racers at my local track, and most everyone who runs F1 has this motor.
wkderf is offline   Reply With Quote
Old 09-22-2016, 07:28 AM   #1684
Trader Rating: 33 (100%+)
Top 2 are the Motiv and the Team Scream motors.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 09-22-2016, 07:38 AM   #1685
Trader Rating: 28 (100%+)
That depends on the type of track you run at. Indoor/outdoor? Small/large? 21/.5/25.5?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 09-22-2016, 09:44 AM   #1686
sbd
The X20 are excellent motors. What turns you use? If you have too much torque at the wheels, just put a larger pinion. With 21,5 X20 we run 2,1 FDR on a large track with 37,5 timing insert.I have tried 1,9 FDR also but it gets too lazy. You would need smaller spur as the stock one allows min FDR of about 2,4.
sbd is offline   Reply With Quote
Old 09-22-2016, 07:40 PM   #1687
We run 21.5 blinky. A mate loaned me a Tekin Gen 2, and it was easier to drive than the LRP. Hence the question, I am basically looking for a motor which is lower in torque so I should get better drive off corners with less wheelspin. That's the theory anyway...
Old 09-22-2016, 07:54 PM   #1688
Get a smaller rotor.
Old 09-22-2016, 11:33 PM   #1689
sbd
I think you can set the X20 to have the same feel like the Tekin by elaborating with the gear ratios and timing. Also it may be your rear tires are not on par with your friend's. You can also try to widen the rear track a bit.
Old 09-23-2016, 11:55 AM   #1690
JayL's Avatar
add timing, run a smaller spur
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 09-23-2016, 12:35 PM   #1691
aracefan's Avatar
Trader Rating: 38 (100%+)
^^ Try this first. Good "cheap" advice.
Drop ~5 teeth (ie, if your running an 86, go to 81. 81, go to 76 etc).
Timing, go up in ~5* increments, till you get the desired feel.
I had to do this when I changed from a MuchMore Fleta ZX motor to a Tekin Gen3 on my 1/12 scale. After changing the gearing a little and not running the same exact timing I was running on the MM, the Tekin is actually a little better. Should've messed with the MM motor a bit - hindsight, it could have probably been faster.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 09-26-2016, 03:08 AM   #1692
Ph3nyx's Avatar
Trans Kit LMP for xray X1 , usable on WRC LM Pro1 and Pr2 Body
STL available here : http://www.thingiverse.com/thing:1791078
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 09-26-2016, 01:03 PM   #1693
I saw those bodies. They look cool.
Rob Jensen
Old 10-02-2016, 09:56 PM   #1694
wkderf's Avatar
curious to know how people are saucing their front tires. Just the inside? full tire? short soak?
Old 10-03-2016, 06:54 AM   #1695
really depends on how much steering you need and the surface you are running on.
Rob Jensen
