Like Tree46Likes
Old 09-15-2016, 09:08 PM   #1666
PACaSteel's Avatar
Originally Posted by wkderf View Post
I'm running a psycho cells racing (awesomatix) 5000 mah shorty pack.
as you can see from the photos above, its gets you very close to minimum weight requirements, but still leaves room to add balancing ballast.
you'll want a 2s "shorty" pack in the 3000-5000 mah range.
Thank you very much. More stupid questions to come.
PACaSteel is offline   Reply With Quote
Old 09-16-2016, 04:13 AM   #1667
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Originally Posted by PACaSteel View Post
Newbie to the class so excuse the ignorance. What batteries do you guys run? I figured out a few pages ago that it's a 2s shorty but have no idea of the capacity needed.
I was running reedy wolfpack 3800's and had plenty juice to finish a race. But I recently switched to to a fantom 5000 100c pack and the car just all around responds better with it.
micrors4guy is offline   Reply With Quote
Old 09-17-2016, 04:20 PM   #1668
Hi guys,
itīs me again with steering-poblems:
Iīve tried this setup tipps from Ph3nyx(Thx):
caster 6°
camber 1.5°
front height 4.5mm
rear height 5mm
800 cSt oil on side damper
2 mm shims on the rear attach of the central damper(800 cSt)
Battery cross
Frontsprings silver 2.0
XR1 Tyres(only these tyres are allowed)
very good steering at the end of the curve, a little less under power in the middle, but not enough steering at the beginning of the curve - some advices for me?
My local track is a small, technical carpet track.
Thx Ralf
dreckschleuder is offline   Reply With Quote
Old 09-17-2016, 06:06 PM   #1669
Originally Posted by dreckschleuder View Post
Hi guys,
Thx Ralf
How tight is your diff?
Old 09-18-2016, 02:48 AM   #1670
shortcut's Avatar
Trader Rating: 49 (100%+)
Hi guys,
Thx Ralf
Never mind.
shortcut is offline   Reply With Quote
Old 09-18-2016, 11:34 AM   #1671
@shortcut ????????
@micrors4guy:
The diff ist between medium and tight......
Old 09-18-2016, 12:24 PM   #1672
shortcut's Avatar
@shortcut ????????
@micrors4guy:
Sorry Ralf, I posted on the wrong thread.
Old 09-18-2016, 02:13 PM   #1673
Ph3nyx's Avatar
Hi guys,
Thx Ralf
You're welcome
try to add some toe out , and maybe add more ackerman.
What tire additive are you using ?
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 09-18-2016, 03:29 PM   #1674
@shortcut ????????
@micrors4guy:
Losen the diff some. Car will wake up
Old 09-18-2016, 11:04 PM   #1675
You're welcome
Itīs LRP Top Grip Carpet 3
I will try
Old 09-20-2016, 12:23 AM   #1676
You're welcome
I will try
So now loosen the diff, changed centershock oil to 450 cSt and I have a little bit more steering.
Next question: So should Iuse a more lighter oil in center shock and sideshock and softer side springs?
Old 09-20-2016, 02:04 AM   #1677
Skiddins's Avatar
How much grip does the carpet have?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-20-2016, 02:10 AM   #1678
It has a very good grip, so the rear of my X1 is quite good, only the front doesnīt work
Old 09-20-2016, 03:27 AM   #1679
Skiddins's Avatar
Make the diff as loose as possible, but without any slipping.
Narrow the rear track
Narrow front track width
Rear ride height higher than the front
Raise rear of center shock so it is more angled.
Stiffer side spring
Only ran the side shock a few times as I changed to the damper tubes.
I can't say any of these will be a miracle cure, but certainly worth trying (if you haven't all ready)
Either way, let us know if any of them made a difference.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 09-20-2016, 09:52 AM   #1680
Stiffer side spring
Thank you so much for your tipps and help, I will try this next week and report it
Thx Ralf
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Fastfreddy74
