Like Tree34Likes
Old 08-10-2016, 07:18 PM   #1591
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by lagcisco View Post
Is this the harder F60 kit tire you guys are referring to?
http://www3.towerhobbies.com/cgi-bin...&I=LXYJA3&P=PU
Yes 51399 is the "Kit" tire that works
http://www.tqrcracing.com/shop/produ...w.asp?p_id=580
Be careful because 54198 is the "Optional Hard" kit style tire that they made before there was a good rear tire offered.
I have used these in extreme cases with some success when nothing seemed to work.
And stay away from the 54199 "Optional Soft" rear offered by Tamiya back in the day as they are junk but they were trying.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-10-2016, 07:39 PM   #1592
Thanks for the info guys, that will help me buy some more sets.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 08-10-2016, 07:50 PM   #1593
NutDriver's Avatar
Trader Rating: 15 (100%+)
I believe that the CRC F1 tires are very close to the TCS tires. Cheaper, too.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 08-11-2016, 06:23 AM   #1594
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Picked up a x1 15 yesterday. What are the best parts to keep on hand?
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 08-11-2016, 07:09 AM   #1595
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Spur, rear axle bearings, and if you have hard boards, an upper and lower arm. Oh, don't forget various shims and the suspension O rings.
Dan is offline   Reply With Quote
Old 08-11-2016, 12:17 PM   #1596
robk's Avatar
Trader Rating: 22 (100%+)
same tire, different logo......
Old 08-11-2016, 04:13 PM   #1597
JayL's Avatar
Originally Posted by racenut123 View Post
People refused to believe I use the Pit Shimizu 574/575 combo on a high traction/High speed track with a track temp of 154 F.
That's because you are always trying to trick us! hehe
574/575 have a MUCH wider range than anyone believes.
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 08-11-2016, 06:24 PM   #1598
Trader Rating: 28 (100%+)
Didn't you hear? I am a Magician.
I ran the 574/575 at the clubrace before the CTS Finale. After, I decided to go 71/72 because I didn't want to mount any new tires for outdoors and decided to try the premounts. Well you know how that ended. I used my older carpet 71/72 sets that ran just fine.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 08-12-2016, 09:32 AM   #1599
JayL's Avatar
you are literally a magician
Stupid rear premounts I blew out two sets as well
how is everyone taping the rear pit insert?
What tape?
tape on tire side?
tape on rim side?
or foam glue?
Old 08-12-2016, 10:53 AM   #1600
shortcut's Avatar
Trader Rating: 49 (100%+)
What tape?
tape on tire side?
tape on rim side?
or foam glue?
I used rubber cement from a bicycle tire repair kit and it worked fine.
shortcut is offline   Reply With Quote
Old 08-12-2016, 11:16 AM   #1601
NutDriver's Avatar
Jay,
Are you talking about gluing the strip to itself to make it a loop, gluing the loop to the wheel, or gluing the loop to the tire?
I glue the strip together to make a loop using 3M spray adhesive. Spray each end, wait 3-5 minutes, then press together. Scirocco14 shared this with me.
USVTA member #111
Old 08-12-2016, 11:33 AM   #1602
Trader Rating: 33 (100%+)
What tape?
tape on tire side?
tape on rim side?
or foam glue?
I use Elmer's rubber cement. Apply to both side, let dry to tacky, then press together. No hard seam and the glue stays flexible.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 08-12-2016, 12:23 PM   #1603
Dan
Dan's Avatar
Elmers rubber cement and a strip of clear packing tape on both sides. Never any splits or issues doing it this way for a few years.
Old 08-12-2016, 01:50 PM   #1604
JayL's Avatar
Jay,
yes to make a loop
I have always just used strapping tape on the rim side
Old 08-12-2016, 02:57 PM   #1605
I use Magic.
1.5 inches of battery strapping tape on the outside slightly heated to get the tape to be a little more tacky. No failures to date. I would use 3M 77 as mentioned,but I have no other use for a whole can of that stuff to warrant buying it.
Team I'm Over It
