Like Tree34Likes
Old 06-28-2016, 05:33 AM   #1546
Trader Rating: 309 (100%+)
Originally Posted by Ray k View Post
F1 paintlabs , Brad Palmer.
How is the touring car I sent you ?
Awesome made a good Usgt car. Thanks
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 06-28-2016, 09:38 AM   #1547
JayL's Avatar
Originally Posted by Skiddins View Post
Oh, and once it's in the position you want, I use a lighter on the sticker to soften it a little which allows you to 'mould' the sticker over the sidewall lettering etc as well.
I use sedan tire warmer cups, works a charm.
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-28-2016, 12:22 PM   #1548
I'm thinking of getting into F1 racing with an X1. I'd appreciate any help on setup you guys could offer. Track is 78X38 CRC High grip carpet. In looking at the options I'm wondering if I should build on the aluminum chassis? Also wondering about an aluminum pod plate? I have no idea what to get as far as front and side springs? As far as the center shock, I'm wondering about the spring for that and also what handling on the car this spring affects? I hear the bearings break pretty easy so I will get some of them, any other spare part suggestions? The F1 class at my track is running 21.5's.
dayno is offline   Reply With Quote
Old 06-28-2016, 12:40 PM   #1549
Trader Rating: 33 (100%+)
If it is the new black CRC carpet, get the aluminum chassis and plate. I also use Tamiya super-soft springs in front and the next stiffer xray spring for the center shock.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 06-28-2016, 04:56 PM   #1550
Skiddins's Avatar
That would mean getting out my tyre warmers, sounds like too much hard work
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-02-2016, 12:53 PM   #1551
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Question : do the X1 pod plates fit on the X10?
liljohn1064 is offline   Reply With Quote
Old 07-11-2016, 05:29 PM   #1552
Had my X1 on the track for the 2nd day today and love it. I had a couple questions about tuning.
1. What handling effects do you get from softening / stiffening the side springs?
2. What / how do you set / tune the rear diff. Not absolutely sure but I think I noticed after I tightenend the diff a couple of times to eliminate the unloading of the light wheel in turns it hurt my turns, I was unable to keep my turns as tight. Basically I could hear the rear unloading so I kept tightening the diff a bit over a few runs. Do you ever want to rid the rear of some unloading? Wondering if the diff is ok and maybe I should go from 1.5 to 2 camber in front to get better / tighter turns, I'm using the 6 degree camber pills.
Thanks,
Dayne
Old 07-12-2016, 01:22 AM   #1553
Skiddins's Avatar
Thanks,
Dayne
Seem to recall being told that if the inside rear unloads too easily, try the softer side springs.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 07-12-2016, 03:11 PM   #1554
What weight oil are you X1 guys using in side tubes on CRC high bite carpet. 40X80 technical track. Thanks!
Old 07-12-2016, 06:38 PM   #1555
Trader Rating: 30 (100%+)
I have not run the X1 on carpet but based on past carpet experience I would start with 15 or 20k.
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 07-13-2016, 02:33 PM   #1556
I've read some are using the Tamiya 54413 damper tubes. Are these better than the X1 kit tubes. Also do they fit the kit ball studs?
Old 07-13-2016, 03:43 PM   #1557
JayL's Avatar
Back on the Xray F1 2015, we were replacing the side shock with the tamiya part. Not sure anyone is doing that with the 2016 xray. the tamiya tube is kind of short and fat.
Old 07-13-2016, 07:38 PM   #1558
Thanks Jay,
I've been running touring cars for a bit and I am familiar with there tuning characteristics. I am now trying to learn about tuning the F1. I have one day on track with a 2016 X1. Can you give me a lesson on how soft / hard dampening affects tuning / handling characteristics in conjunction with soft / hard side springs? I'm also trying to understand how rear pod droop effects handling characteristics of the F1.
Thanks!
Old 07-13-2016, 08:58 PM   #1559
Trader Rating: 27 (100%+)
is there any advantage other than weight to switch to rear carbon axle on x1 ?
Awesomatix-Vbc-Hudy-Orca-motiv-Tsr-
pat5b is offline   Reply With Quote
Old 07-13-2016, 10:14 PM   #1560
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
It's a slight difference. The nice thing about the stock axle is that it's hollowed out. Not super heavy like most F1s out there using a full on steel axle. On carpet, I feel a bigger difference in acceleration. On asphalt, the steel seems to add more rear traction. I am currently using carbon in both my asphalt and carpet X1. Save the $40 if you are running on asphalt.
Dan is offline   Reply With Quote
