Old 06-29-2015, 01:48 AM   #166
Model:TS02064
Name:GT-500W car clear body
TSCAR is offline   Reply With Quote
Old 06-30-2015, 10:46 PM   #167
Default New GT-300W 1/12 Pan car body shell from Teamsaxo TS05021
Teamsaxo proudly release the latest 1/12 pan carbody shell for GT-300W racing in light weight, 0.6mm thickness clear polycarbonate Lexan and the lighter 0.5mm thickness will be available soon. Aimed at 1/12th on-road racers .It features a low-slung, cab-forward design sure to provide exceptional handling characteristics and focused on new shape front fenders that increase steering response while the rear centre vane improves stability at high speeds. It is available now.Included with a decal sheet and window masks.
Old 07-01-2015, 06:39 PM   #168
Model:TS01111
Characteristic:1pcs/bag
Old 07-02-2015, 11:49 PM   #169
Teamsaxo new clothes is designing,which back you like better?
Old 07-03-2015, 07:19 AM   #170
"Teamsaxo proudly releases......" ???
"new shape front fenders......." ???
How can you honestly be proud of this new product - it's a design that's 100% stolen from Protoform....just like you did to our TR-12 body.
If I was in your shoes - I would be ashamed, not proud.
Dale Epp - Protofoprm Race Bodies
PROTOform Race Bodies
www.racePF.com // www.facebook.com/PROTOformRaceBodies // www.twitter.com/RacePF
daleepp is offline   Reply With Quote
Old 07-03-2015, 11:03 PM   #171
Default Teamsaxo release the new cap named TS-211
Teamsaxo is proud to release the 6 Panel cooling caps, made for full cotton twill fabric and nylon mesh material, it features a blue T and black S embroidered on the front and the Teamsaxo logo embroidered on the Visor, Mainly design for mesh is good for comfortable and convenient, the size can be adjusted, it is available.
Features:
Panels: 6 (include 4 mesh)
Specifications: Visor(8cm); head circumference(50-58cm);hood height(11cm)
Contents: full cotton twill fabric + nylon mesh
Old 07-05-2015, 08:06 PM   #172
Model:TS01112
Name:B7 Top plate
Old 07-07-2015, 11:06 PM   #173
Teamsaxo have a new soft weave carbon fibre chassis and top deck for the Yokomo BD7 touring car available. Cut from “soft” 2.25mm material the chassis in combination with the 2.0mm top deck will make for more torsional flex which can help increase traction and side bite in certain track conditions. Being only 85mm wide the chassis also makes for improved ground clearance during heavy cornering.
Old 07-10-2015, 12:03 AM   #174
Model:TS-908
Old 07-10-2015, 12:19 AM   #175
EDWARD2003's Avatar
+1
Bold move Team Saxo racing, bold move.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 07-10-2015, 08:03 PM   #176
Coming from Teamsaxo and made for the HB Pro5 touring car is a new carbon fibre main chassis and top deck. The 85mm wide chassis is cut from 2.2mm material and it features a symmetrical design with the milled motor pocket also being present on the battery side for a more equal left-to-right flex. The design makes the chassis especially helpful in low-grip conditions with the 2.0mm top plate being usable in combination with the optional or standard chassis in order to provide different flex characteristics when needed.
Old 07-12-2015, 06:28 PM   #177
Teamsaxo and VPPRO Glow Ignitor is available,do you want to test it?
Old 07-14-2015, 07:46 PM   #178
Congratulate to Teamsaxo driver Alberto won the place in F1 competition.
Teamsaxo car F1-180-11720486_816029388510290_1685608798_n.jpg   Teamsaxo car F1-180-11694397_816029431843619_2038811934_n.jpg   Teamsaxo car F1-180-11692963_816029371843625_1321065779_n.jpg
Old 07-15-2015, 05:40 AM   #179
antonio_cadiz's Avatar
where are you shop?
antonio_cadiz is offline   Reply With Quote
Old 07-15-2015, 08:43 PM   #180
Originally Posted by antonio_cadiz View Post
where are you shop?
could you tell me where are you from?which products you interested? Glow Ignitor?
Tags
copy infringement, teamsaxo new car body, we copy everything
