Old 05-22-2015, 06:55 PM   #136
Model:TS02071-OR
Name:Aluminium Body Height Adjuster
Colour:Black,blue,orange,red,light blue
Characteristic:1SET
TSCAR is offline   Reply With Quote
Old 05-24-2015, 06:56 PM   #137
Model:TS-619
Name:Teamsaxo tool set
Characteristic:1 set
Old 05-25-2015, 06:23 PM   #138
Model:TS-611
Name:Shock shaft Plier
Characteristic:1pcs/bag
Old 05-26-2015, 10:52 PM   #139
VP-PRO has released the latest body creation, this time designed for the HongNor X3 1/8 buggy. The body features a sleek and low-profile cab forward design that is intended to reduce body weight and maximize stability and speed. The body is made up of high quality 1.0mm clear Lexan.
Old 05-28-2015, 12:43 AM   #140
Model:TS-T3MM
Name:Ceramic bead 3mm
Characteristic:12pcs/bag
Old 05-28-2015, 05:20 AM   #141
sbd
Hi TSCAR,
you have a lot of useful and nice products, but until you dont have sales channel as a web shop, I believe you will not be able to sell them.
sbd is offline   Reply With Quote
Old 05-28-2015, 10:48 AM   #142
Hello
Good afternoon SBD, you can say that city or country are, surely there is a selling point of these products
Best regards
Rcactual
rcactual is offline   Reply With Quote
Old 05-29-2015, 06:32 PM   #143
Model:TS05001
Old 05-31-2015, 08:34 PM   #144
Model:TS05006
Characteristic:1set/bag
Old 06-01-2015, 07:30 PM   #145
Model:TS01004
Old 06-02-2015, 07:28 PM   #146
Teamsaxo GT-300W Car Kit will be available in middle of June.
Old 06-02-2015, 08:40 PM   #147
EDWARD2003's Avatar
You might want to include some LiPo battery stops.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 06-03-2015, 07:14 PM   #148
Model:PS-101
Characteristic:
1pc/bag
TeamSaxo power switch is a tiny MCU controlled on/off switch for your radio controlled model. A simple pish button operates the switch meaning to eliminate teh problems associated with intermittent contac of an ordinary meachanical switch.The sealed unit is plastic and can easily be mounted to the transponder mount of your model or anywhere else you can mount it using double side tape.The switch also features a LiPo mode.by turning this on the switch unit will auto detect low LiPo voltage and cut off power to protect your LiPo from over dis-charging. This of course can be turn off if you have other safeguards in place or using NiMH/NiCad battery.
Old 06-05-2015, 06:55 PM   #149
Model:TS02039
Name:Carbon fiber link parts
Characteristic:2pcs/bag
Old 06-05-2015, 07:00 PM   #150
Originally Posted by sbd View Post
Hi TSCAR,
we are building website shop,maybe will start working in the july.once finished will let you know.
Tags
copy infringement, teamsaxo new car body, we copy everything
