Old 10-22-2013, 11:13 PM   #1
Default trackstar esc 120a problems
i have an emaxx with a trakstar esc 120a and a trackstar 2300 brushless motor my problem is i dont know much about this stuff got from a trade and truck was working fine when i got but know the steering works but no throttle i have a programmer for it not sure what to do please help thank you
green84 is offline   Reply With Quote
Old 10-23-2013, 08:58 AM   #2
Geezatec's Avatar
Like all ESC, ESC has to be Calibrated TX-RX-Motor. All has to connected. Look online to do this. Search calibrating Turnigy Trackstar ESC. Not to familiar with this ESC. More into higher class ESC like Tekins & Novak. All ESC you have to calibrate. Programmer work better with until you calibrating. Then experiment with the programmer. Give it time, in takes a few second to calibrate, It may have chimes or LED's for references, Full throttle to braking then neutral.
Good luck!!!
Geezatec is offline   Reply With Quote
SEO by vBSEO 3.5.0
