Old 06-28-2005, 10:09 PM   #1
Default trf415ms +brushkless what pinion gear????
i need to get a pinion gear for my new 415 ms with stock gear. i am useing a brushless motor and dont know what pitch or tooth to get. any help would be of great help. thanks in advance for any and all help/info. thanks for taking the time to read this too.
hongbits is offline   Reply With Quote
Old 06-29-2005, 05:00 AM   #2
DIMO's Avatar
Default hey
Check your car to see if its the .6 or .4 pitch. That or convert it to xray spurs and pinions
Your pinion needed will depend on the track you race at
More teeth=HIgher top end
Less Teeth= Beetter acceleration
So go out and have a look what the guys at your local track are running in mod, your best bet would be to buy a few or a full set and go from there
DIMO is offline   Reply With Quote
Help super gear and pinion gear jojo RRR Electric On-Road 0 06-18-2007 06:37 PM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 12:09 PM
what pinion gear should I run? duckbutter Electric On-Road 4 02-22-2006 10:33 PM
pinion gear mark123 Electric On-Road 2 07-11-2004 06:00 PM
pinion gear yrless Electric Off-Road 1 03-23-2003 04:46 AM
SEO by vBSEO 3.5.0
