Like Tree8Likes
Old 03-06-2017, 10:58 AM   #646
TT_Vert's Avatar
Trader Rating: 70 (100%+)
Ahh yes I was thinking about this backwards. The shims under the mount will raise the car back up. so if the tamiya are a .5mm shorter I could REMOVE some of that shim under the mount which I'd like to do. Does WCRC have that tamiya spring kit? It'd be a good tuning option to have in my bag.
BTW, CRC support is top notch. I had a couple of pod plates that were a bit out of tolerance and didn't fit in their rear axle bearing carrier. They are sending me out replacements, no questions asked. This is why I love doing business with small American run businesses.
Dave
TT_Vert is offline   Reply With Quote
Old 03-06-2017, 12:18 PM   #647
TT_Vert's Avatar
Anyone question. Has anyone using the tamiya pre mounted tires notice a very loose press fit for the bearings? I can see the bearing actually moving in the molded recess for the bearing. It is allowing quite a bit of slop in steering geometry.
Dave
Old 04-15-2017, 10:26 PM   #648
EbbTide's Avatar
Trader Rating: 35 (100%+)
Hello everyone, I just picked one of these up used and I am completely new to RC F1 so I've got a question about bodies.
Is there a decent Ferarri F1 body/wing set I can fit on this chassis?
EbbTide is online now   Reply With Quote
Old 04-17-2017, 05:18 PM   #649
Moogumby's Avatar
Trader Rating: 31 (100%+)
This one should work.. I think its from the kit itself.. you may be able to get it in white if needed
https://www.teamcrc.com/crc/modules....prodID=7719769
Moogumby is offline   Reply With Quote
Old 04-17-2017, 05:48 PM   #650
EbbTide's Avatar
Thank you for that I just bought a body and wing set and sent it to get the Ferrari livery painted on. Hopefully the painter will do the decals too but I'm just stoked I was able to find a proper Ferrari body. I can't wait to see what it looks like all finished
Old 04-17-2017, 08:15 PM   #651
NutDriver's Avatar
Trader Rating: 19 (100%+)
www.tqrcracing.com has the decals, wings, bodies, etc you're looking for.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 04-18-2017, 01:10 PM   #652
EbbTide's Avatar
I may be a little naive when it comes to RC f1 but is that low profile sanwa servo for the laydown setup Actually strong enough?
Old 04-18-2017, 03:14 PM   #653
Yes, I also use it in my WGT car.
davidl is offline   Reply With Quote
Old 04-18-2017, 04:28 PM   #654
EbbTide's Avatar
That's pretty sweet considering the low cost of the servo. I'm going to have to pick one up.
This is the one you have?
https://www.amainhobbies.com/sanwa-a...53252b/p587622
Edit: well I think I have everything I need for this thing. I'm just not looking forward to assembling the f2012 body. I hear it's a bit tricky?
Old 04-18-2017, 08:31 PM   #655
Nope. I have the SRG-HR. It sells for around $100. Faster than the one you show. Having said that, I believe the one you show will work as it is used by many in 1/12 cars. Both have the same size case.
Old 04-23-2017, 04:06 PM   #656
TonyK's Avatar
I picked up a CRC WTF-1 and having an issue with the 2-56 button head screw. I'm having a problem finding a hex to work. Can someone recommend a hex set that would work with this car. The last car I built was an Associated T3, so it has been a long time.
TonyK is offline   Reply With Quote
Old 04-23-2017, 04:25 PM   #657
EbbTide's Avatar
Well any set of standard hex drivers should work. I recommend MIP drivers and quick release tips
Old 04-24-2017, 07:12 AM   #658
2-56 screws use an .050 hex driver.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 04-24-2017, 05:16 PM   #659
Moogumby's Avatar
Does anyone know if the CRC guys are in the office? I have sent a few emails on a backorder status past few weeks but haven't gotten a reply.
Old 04-24-2017, 09:06 PM   #660
Probably on their way home from Denver. I would say they should be in the shop by Wed., but that is just a guess.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Solara
