Like Tree8Likes
Old 01-14-2017, 03:34 PM   #556
Originally Posted by Serzoni View Post
Don't use the upper section of the wing, and for the body post just use the post and longer screw that comes with the body.
Do you happen to have a picture?
russellnyg745 is offline   Reply With Quote
Old 01-14-2017, 08:44 PM   #557
http://racepf.com/images/howtos/F1-A...Insert-web.pdf
Serzoni is online now   Reply With Quote
Old 01-14-2017, 09:07 PM   #558
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Blues Hockey View Post
I am just getting back into the on road racing after years away from it. I bought a new CRC F1 car and I am trying to figure out where the front suspension mount shims need to go. I am using a protoform front wing and the wing is way to tall to fit under the suspension mount as shown. I assume that I will have to dremel the front wing but do I need to run both suspension mount shims? If so, where do they go? On top of the carbon fiber? Thanks in advance for any healp.
The suspension mount shims control ride height, but you may also use them to change the height of the upper arms as well.
Ride height - under the entire front end assembly
Upper arm angle - on top of the carbon fiber, under the upper arm mount
Old 01-14-2017, 10:27 PM   #559
Thank you sir.
Blues Hockey is offline   Reply With Quote
Old 01-29-2017, 09:08 PM   #560
TT_Vert's Avatar
Trader Rating: 69 (100%+)
Can someone explain what "micro" servos fit in the laydown position on this? I don't have one yet but doing my research on them. Is the change in center of gravity significant enough to ensue I do this or is it more of a tuning thing? I'd think if it was better on all surfaces then they would be designed that way. Perhaps it was a packaging thing?
Dave
TT_Vert is offline   Reply With Quote
Old 01-30-2017, 05:09 PM   #561
Default Personal Message
There is a PM in the mailbox for Blues Hockey
davidl is online now   Reply With Quote
Old 01-31-2017, 09:35 AM   #562
Dave
I think it's more of a "we use this servo in our 12th scales and WGTs, so let's use it in the F1" thing. If you look at the team drivers cars, most have moved to using shorty servos in the upright position. When I looked at the Sanwa servo, I couldn't find one anywhere in the states.
Old 01-31-2017, 09:40 AM   #563
TT_Vert's Avatar
Ok so the typical position is the SOP as of now then. I don't currently have this car, can you tell me the max servo dimensions that'll fit in this thing? Shockingly the manual only states one servo that they state can be screwed in on page 8 but nothing on servo maximum dimensions or the like.
If installing an Airtronics/Sanwa 94761 or SRGHR, then no graphite plates or aluminum mounts are needed. Bolt down the servo to these two holes.
Dave
Old 02-02-2017, 12:33 PM   #564
TT_Vert's Avatar
After doing some research I'm having issues finding a setup station for this. The vendors I speak to say theirs won't work w/ F1 kits. Is there one out there that works?
Dave
Old 02-02-2017, 12:39 PM   #565
Trader Rating: 114 (100%+)
Most any made for a Pan Car. Here is a cheap one.
https://hobbyking.com/en_us/tracksta...up-system.html
Chris Furman is offline   Reply With Quote
Old 02-02-2017, 12:40 PM   #566
Still Bill's Avatar
Dave
I use the Hudy Setup Station for Pan Cars for F1, WGT and WGT-R. A used one should go for around $75.
The Hobbyking one above looks acceptable.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-02-2017, 12:42 PM   #567
TT_Vert's Avatar
Forgive my ignorance. I thought these required 12mm hex hubs not bearing in wheel? Maybe there is a different kit for Touring car and Pan car?? At least the HUDY and YR ones.
Dave
Old 02-02-2017, 12:45 PM   #568
Still Bill's Avatar
Forgive my ignorance. I thought these required 12mm hex hubs not bearing in wheel?? At least the HUDY and YR ones.
Dave
All are bearing in wheel and just go on the front end of the car.
Bill
Old 02-02-2017, 12:45 PM   #569
Dave
No, for the PAN CAR versions, its requires you to install bearings.
Old 02-02-2017, 12:51 PM   #570
TT_Vert's Avatar
Ok great thanks. So there appear to be different kits which have different machining for pancar and touring car wheel retention designs..
