Like Tree8Likes
Old 02-16-2015, 11:53 PM   #331
aittam's Avatar
Originally Posted by Still Bill View Post
Good things to try...But, increasing caster would be "two washers forward" (to move the upper arms back).
What surface are you racing on?
Bill
Hi, we race on a high bite asphalt track. At the end of the day it gets really sticky and rubberized.
http://rcmanici.blogspot.com
aittam is offline   Reply With Quote
Old 02-17-2015, 03:22 PM   #332
YoDog's Avatar
Trader Rating: 26 (100%+)
Bill
A few things that have got my WTF-1 working sooooo much better on carpet has been:
1) Full (-) Castor. AKA all washers forward.
2) 1.5deg (-) camber
3) .50 front springs
4) 30wt oil and purple spring on the middle shock.
5) Most important thing is droop... start at 1.5mm and increase till steering becomes more reactive but not twitchy.
Oh yeah... 15-25% drag brake.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 02-17-2015, 06:57 PM   #333
Still Bill's Avatar
Nice post YoDog. That is exactly how my new WTF-1 is setup for its first race...except the caster which will have the upper arms in the middle (one washer on each side).
We will be at the Stockton Fairgrounds for F1 racing on carpet this Sunday, Feb 22.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-17-2015, 08:42 PM   #334
YoDog's Avatar
Bill
I wish I could make it up there but I'm no longer in Fresno these days.
Since moving to Santa Barbara, I frequent TQ and Camarillo more and more.
I had been struggling with inconsistent front grip for quite a while but when I dug in my heals and really looked at what was happening, I realized that the weight wasn't transferring forward fast enough at turn in so the car would push terribly at higher speeds. Once I realized this, it was much easier to decide what to change. Now if I can get more durable steering knuckles, I'll be a really happy camper.
Old 02-17-2015, 10:39 PM   #335
Still Bill's Avatar
Buy a CRC WTF-1 and I will show you Dumper's steering knuckle trick...LOL
Bill
Old 02-18-2015, 12:08 AM   #336
aittam's Avatar
Does battery position affect steering?
What is the difference between:
- front battery, esc in the back
- front esc, battery in the back
Thanks.
Old 02-18-2015, 09:21 AM   #337
YoDog's Avatar
Bill
Ohh Bill... I was one of the first to buy the WTF-1
Can you post some pics?
Thanks!
Old 02-18-2015, 09:02 PM   #338
Still Bill's Avatar
Thanks!
And I was one of the first to buy the GenX-10 Pro when it was a 13.5 with a 2S battery pack...fast, fast, fast.
Just finished putting a D4 21.5 motor in the WTF-1; so, it is nearly done. Only need some titanium steering links from Lunsford (which should arrive tomorrow); TOP ball cups; paint the driver; add ballast to bring the puppy up to legal weight and balance the chassis; and, figure out the gearing.
Heading out to the garage to take pics now.............Back from my garage and here are the results.
That is a Hobbywing Just Stock ESC. At under $50, this is the lowest cost ESC I have ever owned...By several times...LOL
Do have a new Ferrari F-60 body from TQ Racing to paint and sticker up properly. The pictured body is just something to get the car on the track this weekend...OK, it's a hack job...more LOL.
In my real racing days, I always drove formula cars; so, it is about time that I finally got one of these.
Bill
New CRC F1 At IIC-f1-001.jpg   New CRC F1 At IIC-f1-003.jpg   New CRC F1 At IIC-f1-004.jpg   New CRC F1 At IIC-f1-005.jpg
Old 02-18-2015, 09:27 PM   #339
Still Bill's Avatar
Thanks!
YoDog,
Before installing the #1544 Upper Arm/Steering Block Ball into the #3221 Steering Block, Dumper reminded me to increase the size of the opening in the Steering Block to prevent the Ball from coming into contact with the edge of the opening.
Actually, this trick works for all CRC pan cars with the newer front ends. I have been doing this for years with great results in durability on my WGT cars.
I use a small rat tail hobby file to do this modification to the Steering Block.
Bill
Old 02-18-2015, 10:12 PM   #340
YoDog's Avatar
YoDog,
Bill
Thanks Bill, I'll give that a try.
Something else that I just added is replacing the rear most screws holding the pivot block to the lower suspension plate with longer screws through 8mm long standoffs that act as steering stops since the WTF-1 doesn't have anything to prevent the steering blocks from over rotating. So far so good.
Old 02-19-2015, 07:07 AM   #341
Trader Rating: 33 (100%+)
I used long ball studs for the same effect. Have only lost one knuckle since, but I sheared the pin in that one, lol.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 02-19-2015, 08:54 AM   #342
YoDog,
Bill
How much material are you taking off?
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 02-19-2015, 09:11 AM   #343
liljohn1064's Avatar
Trader Rating: 17 (100%+)
It will be interesting to see how the car behaves now that its up to weight. I had to add 62 grams.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-19-2015, 09:25 AM   #344
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
At the birds I added a good thick layer of rubberized glue (I got it from DD audio) to keep it from cracking. And glued the threaded cap into the nuckles. I had some hard hits in the quals and never broke them... But when they do I will open up the slot cause that is what looks to be what breaks them... I can see a spot where it looks to have made a dent in the plastic but after adding the rib of glue over the top it didn't break
jlfx car audio is offline   Reply With Quote
Old 02-19-2015, 09:30 AM   #345
waltss2k's Avatar
What is the legal weight ?
waltss2k is offline   Reply With Quote
