Like Tree8Likes
Old 09-23-2014, 07:42 PM   #166
MAD916's Avatar
TQ'd Last Thursday night the first night out...... nice ride looking forward to the season
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 09-24-2014, 10:51 AM   #167
MarkBurgess's Avatar
Originally Posted by YoDog View Post
My WTF1 is all together now but there is one little problem. The PF F1-Thirteen doesn't fit properly. Unfortunately the rear of the body has a really low profile which looks really nice but the CRC chassis has components that sit higher than other cars and unless I butcher the body, it won't sit low enough to work properly. I will post some pics tonight. I love the body but it doesn't fit. However, the Tamiya F60 does fit well. Sorry Dale, I was so enthusiastic about the new bodies but you may need to create one catered to the WTF1 specifically.
That's odd...I took my F60 shell from my old F104 V2, and with light trimming it fitted straight onto the WTF1. It will do for a pre-IIC shakedown run in the UK.
Most shells need a fair bit of cutting to fit the narrow rubber cars. I managed to make an older Protoform shell designed for the F103 to fit my rubber car with some work.
My advice is stick with it
MarkBurgess is offline   Reply With Quote
Old 09-24-2014, 11:37 PM   #168
YoDog's Avatar
Trader Rating: 26 (100%+)
That's what I was somewhat poorly expressing. The F60 fits quite nicely however the new Protoform body doesn't. The rear of the new body is too low profile so it sits on the shock brace. This will bind the rear end as it sits now. I hope to post some pics tomorrow.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 09-24-2014, 11:40 PM   #169
YoDog's Avatar
Originally Posted by al dente View Post
Can't be any lower than this. I don't see the problem.
Looks like I just need to keep on trimming...
Can you post a pic of the car on the bench so I can see the ground clearance to the bottom of the body? I just want to see how high the pod sits.
Old 09-25-2014, 04:08 AM   #170
I am expecting my WTF-1 kit to arrive soon and I'm wondering about which servo I can fit in.
I have a couple which have been used in CRC's 1/12 cars. One is Futaba 6250 and the other is a JR/Graupner. They both have a few mm more length than the Sanwa which was recommended here a few pages back.
I'm asking because we don't have any of these cars in my country yet so there is no way to test or take measures myself.
What is the max. servo hight from chassis up that fits under for example the popular F60 body?
jarkko is offline   Reply With Quote
Old 09-25-2014, 08:58 AM   #171
al dente's Avatar
the edges of the body are flush with the bottom of the chassis.they have to be to clear the ride height gauge in tech.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 09-25-2014, 09:25 AM   #172
Any 1/12th scale sized servo will fit.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 09-25-2014, 04:28 PM   #173
YoDog's Avatar
Thought I'd post some pics of the build.
New CRC F1 At IIC-20140924_212511comp.jpg   New CRC F1 At IIC-20140924_213419comp.jpg
Old 09-27-2014, 11:39 AM   #174
WTF built and shakedown run completed. Two new shells painted, cut out and finished.
Packing for the IIC will start on the tone...
Old 09-28-2014, 05:51 PM   #175
Does anyone have any setups to share.
MJSGas is offline   Reply With Quote
Old 09-28-2014, 07:38 PM   #176
al dente's Avatar
The parts, springs, and directions included in the box will give you the set up we have been running. you may want to space the rear of the car out to 190.
Old 09-29-2014, 06:50 PM   #177
Thank you Mario
Any suggestions on camber/castor/toe-in. Also king pin length.
Thanks again
Old 09-29-2014, 09:08 PM   #178
al dente's Avatar
All good questions, but all things that change in the natural course of tuning. Start with one degree of camber. More camber will give the car more steering all the way through the corner, but too much will make the car tippy. If you go way overboard, you will take away the contact patch of the tire, and it will go from tippy to push.
I run both caster shims back, from what I have experienced, moving them forward will calm the car down.
I use kingpin length to adjust the attitude of the car in the corner. A looser kingpin will cause the car to roll more in the corner, which gives it more steering, especially at entry and mid corner, but will also make it more tippy. When measuring kingpin length, I measure from the bottom of the white spacers to the e clip groove. Start at .450, adjust from there.
We always run just a shade of toe out (1/2) to make the car stable down the straight.
Remember that everyone drives differently and you have to find a setup that works for your style. There is no magic setup that works for everyone.
Old 09-30-2014, 04:50 AM   #179
Here is something else to consider. Full size battery pack with the speeder and receiver on either side of the battery. Added weight won't hurt the car at all. Just another option to think about.
chuck
mackin is offline   Reply With Quote
Old 09-30-2014, 06:22 AM   #180
I ran the first two UF1 Midwest races at the Gate this past weekend. TQ and won all three mains on Saturday, and won two out of the three mains on Sunday. Hot lap and quickest averages every time on the track. I ran my standard setup, which is what comes in the box. Use all of the kit springs and 10k in the tubes. I also used the CRC Part#4185 F1 body. The car was on rails all weekend on the TCS tires which is what we will be using at IIC.
