Old 02-28-2014, 01:12 AM   #1441
A knowledgeable friend of mine who did some testing on equipment he had at work, said AE and Losi have more natural pack to them, and are thus good for asphalt. But muchmore is more linear with closer more consistent spacing between weights, and is better for carpet. He said there's a couple others that are actually a bit better, but he runs muchmore because it's easy to get.
-Mike
Old 02-28-2014, 01:45 AM   #1442
Skiddins's Avatar
Originally Posted by walzjer View Post
I know but wich company are you using?
GM, Xray or something else? I remember from my old days that they can hardly be compared.
I've stuck with Xray as I don't use that much and I know it's what most team driver sheets are using
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-28-2014, 08:11 AM   #1443
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by grippgoat View Post
Do you think that would apply for a tight high-grip carpet track?
-Mike
I don't think so as cars on carpet slide a bit, a heavy diff would make it do loops on power, although I have very minimal carpet experience
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 02-28-2014, 09:01 AM   #1444
Bar
Originally Posted by chasingthepack View Post
the t4-14 is a better all round car as it works well in all conditions,the bd7 appears to only go well on med to high grip,a few have tried to run the bd7 in the winter champs and failed and changed brand,at the last meeting a very good stock driver with a bd7 was beaten by a t4 13 and a t4 14
it was around 8c track about 6 started damp and dried out,at my local track the bd7 only does well in the summer
Most the guys with the bd7's have gone to ball diffs for outdoor winter racing, seems to transform the car, the car seems to locked in with the gear diff, even with really thin diff oil. The ball diff really seems to allow the car to rotate a lot more. Still doing well with my t3 2011 though, also with a ball diff :P
Luke Burr
Bar is offline   Reply With Quote
Old 02-28-2014, 09:02 AM   #1445
Trader Rating: 57 (100%+)
I use associated too just because that is what my local carried. I think its best to use all of the same oil so if you need to increase/decrease you have a comparable product.
PROMODVETTE is offline   Reply With Quote
Old 02-28-2014, 09:40 AM   #1446
Odin544's Avatar
Trader Rating: 93 (100%+)
Thats interesting Mike. It would be cool to see info on something like that.
TriCitiesRC.com
Old 02-28-2014, 11:17 AM   #1447
Unfortunately, he doesn't have the data anymore. :/
-Mike
Old 02-28-2014, 06:38 PM   #1448
Ultra_Aussie's Avatar
I'm about to order my Xray.
Make sure you order one of these too. Might save you a few headaches
Graphite Bumper Upper Holder Brace # 301215
http://www.teamxray.com/teamxray/pro...0Brace%203.5mm
Ultra_Aussie is offline   Reply With Quote
Old 02-28-2014, 07:07 PM   #1449
Oh yeah, I forgot about that. It's absolutely required. I had trouble sourcing the brace, and thought I'd be okay without it for a couple days... One head on hit to something with my t4'14, that wasn't that hard, and it split the front of my chassis. >_< It was repairable with CA, but wouldn't have happened with the brace.
-Mike
Old 02-28-2014, 08:44 PM   #1450
-Mike
I didn't know it was a must have and in my first race I got rammed
Old 02-28-2014, 11:15 PM   #1451
Looks just like mine.
-Mike
Old 02-28-2014, 11:55 PM   #1452
millbank's Avatar
Also when fitting the brace I shimmed it up by 2mm after mine took a wack and it popped under the bulk head causing the screws to pull through the chassis. The other thing to do is run the older bumpers off a t2/3
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 03-01-2014, 12:45 AM   #1453
Brokin Racing's Avatar
R/C Tech Elite Subscriber
Trader Rating: 68 (100%+)
Did that on the build, '14 one is like a back pocket in a singlet.... useless
Xray T4'17 - LRP - PF - Futaba - Muchmore
Brokin Racing is offline   Reply With Quote
Old 03-01-2014, 01:31 AM   #1454
There is a hard bumper now available from xray in case you guys didn't know.
It's much much harder!
Andrew S is offline   Reply With Quote
Old 03-01-2014, 05:14 AM   #1455
Anywhere in the states have a graphite brace? Looks like they are out nearly world wide. rcmart and rcmarket are out too.
