Old 02-19-2014, 03:32 PM   #1396
Skiddins's Avatar
Originally Posted by grippgoat View Post
So I put the car on scales and played with battery orientation. For both my IP and Team Powers 6800 packs, it changes the front rear weight split by about 5g. That's with the wires plugged in. So almost no difference.
-Mike
It would only be a small difference (try weighing the ends of the battery pack itself) but I did find that on a fast track with a high speed chicane it did help plant the rear a little better when weight was put to the front.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-19-2014, 05:01 PM   #1397
xrayracer1's Avatar
Thanks for the info guys ill look into it.
xrayracer1 is offline   Reply With Quote
Old 02-19-2014, 06:52 PM   #1398
Trader Rating: 57 (100%+)
I use a 2 screw method while assembling my diff. This allows any overflow to seep out of the open holes. Its the same way Paul shows to build his front diffs in this video.
http://www.youtube.com/watch?v=SmfInldgGsc
PROMODVETTE is offline   Reply With Quote
Old 02-19-2014, 10:24 PM   #1399
xrayracer1's Avatar
Originally Posted by xrayracer1 View Post
Hey guys, have any of you had the rear gear diff leak? I've just finished building my t4 '14 and haven't had a chance to race it yet, and I've noticed there is some fluid on the stand it sits on. Have any of you had this problem?
Just to add, should I replace the rear belt? It's covered in oil as well.
Old 02-19-2014, 10:39 PM   #1400
I'd just wipe it down with a towel. The oil will fling off fast enough.
-Mike
Old 02-19-2014, 11:30 PM   #1401
morgoth's Avatar
My diffs always leaks a little when new. After 2 or 3 meeting it's over. I think the gasket and the O-rings need to settle first.
The belt is fine after it's soaked with oil. I try to clean it with a paper towel as good as possible and then run it. I won't slip or break.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 02-21-2014, 07:58 AM   #1402
TEM
TEM's Avatar
Default Motor won't fit?
What do you do if the motor shaft is too long and it drills into the battery? Do you cut/grind the shaft shorter? OR shim the motor outwards? If you do, what shims would you use between motor and motor mount? Will it make the motor more likely to shift when crashing?
TEM doesn't advertise for free! Does anyone else notice that a LOT of companies are not even packaging decals with their products?
TEM is offline   Reply With Quote
Old 02-21-2014, 08:00 AM   #1403
B00t13g's Avatar
R/C Tech Elite Subscriber
I grind the motor shaft.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-21-2014, 09:25 AM   #1404
erchn's Avatar
+1
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 02-22-2014, 10:44 AM   #1405
Samich's Avatar
Trader Rating: 11 (100%+)
Same, here. Out of the box mine leaked like crazy. Rebuilt it; same thing. I pulled it apart again and on the third rebuild build I:
Used 2000cst AE oil instead of the kit oil (recommendation based on local track)
Used a fresh o-ring (original had swelled up too much to fit)
Installed the paper gasket with shiny side facing the mating surface
and added exactly 1.3g oil (I bought a cheap scale from Amazon just for this).
So far, its looks like that did the trick.
Samich is offline   Reply With Quote
Old 02-22-2014, 01:50 PM   #1406
morgoth's Avatar
I don't use the O-ring. The paper gasket is fine.
My XB4 also leaked after I just build it. I think that the small O rings expand a little after the soaked for while in oil.
Old 02-23-2014, 03:34 PM   #1407
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
+2 as above, grind motor shaft.
...anyone tried the 3Racing 64P Spur Gears, looking to find out if they fit, in order to use some of their odd tooth-count ones to obtain different FDR's?
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 02-24-2014, 09:22 PM   #1408
alecladanga's Avatar
had the same problem at TITC 2014 last week, gear diff leaking.
I approached Hagberg and asked him how to solve it and he told me that none of the factory drivers including himself use the O-ring. The gasket is fine by itself.
1st time I ran the kit without the o-ring, very minimal leak, 2nd time around, none
Old 02-24-2014, 09:29 PM   #1409
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
The new leespeed gears are very good as well. It's what I've been running since Vegas. Just now started using 84 pitch stuff too.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 02-24-2014, 10:21 PM   #1410
rangerjkb's Avatar
Thanks Eric, appreciate the recommendation and will check out the leespeed and the 84P gears. The new ORCA VXX esc is working great!
Jason Burks
