Old 02-15-2014, 06:10 AM   #1366
CristianTabush's Avatar
Trader Rating: 11 (100%+)
If you are running mod, the Spec R R1/S1 belts work and are the most durable ones I have found. They are also fairly inexpensive. Just make sure it's the belts for the R1/S1 and not the Spec R low Friction belts for XRAY. Those are essentially the same as the stock ones.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-15-2014, 06:17 AM   #1367
Originally Posted by bigtez View Post
Broke a rear belt on the weekend and need to order a replacement and spares. I notice on RCMarket they list the top, cso, HB and yokomo as being compatible with the T4. Are any of them better than the X-rays or at least of similar quality. I would rather pay less for one of the other brands than the exorbitant local Xray prices.
I'm having good luck with ARC rear belt for my T4
Yiming
SniperWJ is offline   Reply With Quote
Old 02-15-2014, 04:26 PM   #1368
bigtez's Avatar
Thanks Christian and sniper. Ordered 4 belts from spec r for about the same price as one xray belt locally. Hopefully they will be here before our next race meet.
Terry Langham
www.qrccra.org.au
bigtez is offline   Reply With Quote
Old 02-15-2014, 09:54 PM   #1369
when i had a Spec-R R1 I've never broke any belts for 2 races. One weekend with the T4 I broke 2....geez.
*i do know how much tension to set ok...
cheapskate.brok is offline   Reply With Quote
Old 02-15-2014, 10:26 PM   #1370
Trader Rating: 20 (100%+)
I find that odd. I've been using the xray belts in mod for a two years now and have only broke one belt, outside. I'm sure they break but if I lost two in a weekend I would be looking to see what else is wrong.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 02-15-2014, 11:40 PM   #1371
kinga's Avatar
Trader Rating: 15 (100%+)
Has anyone tried the new T4 Aluminium chassis 301136 yet? It says it is for carpet, intrigued how it would go on med-high grip asphalt
kinga is offline   Reply With Quote
Old 02-16-2014, 12:16 AM   #1372
spencehotbodies's Avatar
Don't think it's for asphalt.
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 02-16-2014, 12:32 AM   #1373
kinga's Avatar
i know its not meant for asphalt, just interested if anyone had tried it. Sick of ripping up carbon chassis edges, thought alu might be tougher and more wear resistant.
Old 02-16-2014, 02:20 AM   #1374
Fair enough, it would probley be to stiff.But worth a try. It's retails about 100 so could be an expensive upgrade.
Old 02-16-2014, 08:25 PM   #1375
Trader Rating: 13 (100%+)
Questions??
Need help...
I need a starting point for a final drive on a 120' x 60' for Blinky 13.5(D3.5). Also which spur/pinion combo to get me there?
Thanks for the help,
Joe
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 02-16-2014, 09:49 PM   #1376
Bullets forwards or backwards? What say you all?
Hagberg was bullets back in his latest chassis focus. I usually run bullets back to keep wires short, but the weight isn't an issue in this car.
-Mike
Old 02-16-2014, 09:56 PM   #1377
Danny-b23's Avatar
Originally Posted by lpittman View Post
Hey man!
Trying to learn myself and wanted to ask you a couple questions about your setup.
Why do you choose not to run the foam inserts in the suspension?
And for your front roll center setup why do you have the FF on the outer most hole and the FR on the middle hole? What's the idea behind this?
Also I saw you are running 4.8mm front and 5.0mm rear ride height, I've always been told the minimum ride height is 5mm as that is what the rules are. What's the reason for running 4.8?
Cheers
Luke
Firstly, about the foam inserts. The last few years I've always run my car with as close to 0 or almost negative rebound in the shock in an effort to make the car more planted. The foam inserts add rebound and that wasn't something I was looking for at this race. Maybe on asphalt, but 0 rebound always feels best to me on carpet.
Second, the front roll center inserts were that way because I had added what's called arm sweep. Its like giving the front some inboard toe out, so when it dives down into the corner under braking it's more stable and easier to push.
Third, the ride height. When the ride height is tested, the procedure generally is to not set (push down) the suspension before the test. Now, if they were to explicitly say they were going to be setting the suspension, I'd run a lot higher ride height, but as long as they don't you can get away with a little bit under.
Hope this clears some things up.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-16-2014, 11:26 PM   #1378
lpittman's Avatar
Excellent thanks Danny!
Luke Pittman
WCICS Website/Social Media Director
ORCA RC RC America/XRay/Hudy PROTOform MOTIV RC Avid RC Apex RC/ProSpec ProLevel RC Max Power America
lpittman is offline   Reply With Quote
Old 02-16-2014, 11:35 PM   #1379
morgoth's Avatar
-Mike
Bullets in the rear is usually better on carpet.
Bullets in the front make the rear loser and is better on asphalt.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 02-16-2014, 11:37 PM   #1380
Odin544's Avatar
Trader Rating: 93 (100%+)
-Mike
I've always been under the impression it was more of a weight balance thing. The end with the bullets would be lighter as the packs are towards the opposite end. I've never really verified this so I don't know if thats 100% true. I guess it would be very easy to test with 4 scales. Just check the corner weights with the lipo both ways and see if there is any difference.
That being said, I always run mine with bullets back for the shorter cleaner wiring.
TriCitiesRC.com
