Old 02-11-2014, 11:13 AM   #1321
The new one is two sprues each with 2 sets of pistons and two shaft guides. I think the old one was that way, too.
I really want xray to revise their swaybar endlink design to make detweaking easier and finer. Swaybars are definitely my least favorite part of building an xray.
EDIT: Also, I noticed the rear arms were overly tight on the hingepins just in my hands. But with the arms on the car, they're nice and free. I wonder if they actually mold the rear arm to account for the very slight tweak that gets put into the hinge pin with the inboard rear toe.
-Mike
Old 02-11-2014, 11:36 AM   #1322
-Mike
There might be something in the works for that.
Picture taken from Alex's facebook.
Regards,
David
niemand is offline   Reply With Quote
Old 02-11-2014, 11:37 AM   #1323
Originally Posted by daleburr View Post
Mine were white as well, and it came from RCDisco. Think they've made a running change.
They're still moulded.
It does make it easier to build the shocks as you can see dirt/air inside the shocks a lot easier.
White pistons here too, does it really make seeing bubbles easier, i cant recall from my last shocks i built!
Fly'n Fish is offline   Reply With Quote
Old 02-11-2014, 11:44 AM   #1324
-Mike
Maybe it pivots in the blocks and not the arm itself? I doubt they mould the plastic to suit a slight tweak in the pin given the tweak changes angle as the arm swings but who knows?
Old 02-11-2014, 12:22 PM   #1325
Jerz616's Avatar
Trader Rating: 49 (100%+)
Regards,
David
What is it that you see? Everything looks normal about his swaybars.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-11-2014, 12:33 PM   #1326
Apart from the different roll bar ends and vertical ball stud. Looks like they could be off the HB TCX(X).
cyclonetog is offline   Reply With Quote
Old 02-11-2014, 01:00 PM   #1327
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
They are from the ARC car.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 02-11-2014, 04:42 PM   #1328
Odin544's Avatar
Trader Rating: 93 (100%+)
I'm building a new T4'14 I picked up in Hong Kong a couple weeks ago. A couple differences are that the shock pistons and shaft guides are a white plastic now, and they have different screws for the wheel hexes that seem to be much better.
-Mike
I got my '14 a while ago (couple months) and it had the updated screws and shock parts with it. The screws are definitely better than the pervious ones.
-Mike
They are working on a design just like what ARC is currently using. You can use the ones from the ARC car you just have to cut the sway bars down in length a little bit. It's a much better design for sure!
TriCitiesRC.com
Old 02-11-2014, 05:14 PM   #1329
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Originally Posted by Odin544 View Post
Is anyone using the Protoform GX body? I'm curious how it handles compared to the Speed 6 and LTCR. I'm running indoor on carpet. I've heard some say its less steering than the Speed6 and I've heard it has more steering. Cant seem to get a definitive answer. Also if you have tried it how did you mount it?
Tried a friends GX body, on my car with existing setup for the LTCR LW-17.5 TC, on med grip carpet last weekend. Car pushed on entry, mid corner & exit had decent steering, produced more overall stability (body was mounted centered and had less steering than LTCR). Just completed painting my GX body for testing this week. I believe the car will need some tuning from current setup to get it to work well. Several drivers at MRH running Modified are liking the Speed GX body, but Stock drivers are prefering the LTCR.
+1 on the updated parts
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 02-11-2014, 05:36 PM   #1330
Skiddins's Avatar
Originally Posted by chasingthepack View Post
are you having to swim home yet? datchet looks horrendous on the news
Not yet.
Think it would have to come up a few more feet first.
Though to add to the worry the power went out for 4 hrs
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-12-2014, 12:24 AM   #1331
My trasponder.
Regards.
MaNoN is offline   Reply With Quote
Old 02-12-2014, 01:23 AM   #1332
Trader Rating: 18 (100%+)
That's the freshest transponder I've ever seen.
viet is offline   Reply With Quote
Old 02-12-2014, 10:42 AM   #1333
Originally Posted by MaNoN View Post
My trasponder.
Regards.
hello, i want to cut the wires but i want to do it with one pliers user to close the conector, did you use it or you soldered... this is my other option??
chachotu is offline   Reply With Quote
Old 02-12-2014, 11:30 AM   #1334
morgoth's Avatar
Since he has black wires, I'm quite sure he soldered.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 02-12-2014, 11:40 AM   #1335
Some people just use a sharpie.
-Mike
