Old 02-09-2014, 08:48 PM   #1306
Odin544's Avatar
Trader Rating: 93 (100%+)
Orca VXX
TriCitiesRC.com
Old 02-09-2014, 08:49 PM   #1307
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Powerbroker View Post
Which one should I go with?
Orca VXX. I switched from the r10 to orca and it's been the best choice. It's so much smoother then the r10. You can't go wrong with either,but the orca is much better.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-10-2014, 01:04 AM   #1308
Originally Posted by Odin544 View Post
Were you using the T4 bumper? Mine is a T3 bumper thats cut down to the same thickness as a T4 bumper. So It's much firmer.
Yes it was a firm bumper, it seemed like a good idea at the time, not so good when I had to buy a new transponder because the wire got cut where they exit the epoxy that coats the curcuit board, couldn't solder them back on.
Bb
bucketboy is offline   Reply With Quote
Old 02-10-2014, 04:29 AM   #1309
Anyone else got rim rub on the front top ball joint? I put a set of muchmore wheels and tyres on and have almost full contact! Half an hour with a blade has them nicely clear but surely this is not common to all wheells. I have 2mm shims under the joints by the way....
Fly'n Fish is offline   Reply With Quote
Old 02-10-2014, 04:49 AM   #1310
Mikkel_R's Avatar
Yes had the same problem with Revlite wheels which the Sorex come mounted on. Ive changed mine to the open type which I think was posted earlier in this thread.
Mikkel_R is offline   Reply With Quote
Old 02-10-2014, 06:51 AM   #1311
chasingthepack's Avatar
i have 2 R10 pro's ones in my sons car,and i tqed yesterday against mostly the hobbywing v3 and the reventon pro,still more punch than the others,havnt been up against the vxx,but the orion is still a very smooth and competative esc,and they have just brought out a new version of it,mines the 160amp 2/3 s,and i have used it in boosted as well as stock ,the orion really likes the lrp x20 motors,didnt do as well with the gm motors though,these have both been in use for 12 months without an issue
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 02-11-2014, 02:22 AM   #1312
I'm building a new T4'14 I picked up in Hong Kong a couple weeks ago. A couple differences are that the shock pistons and shaft guides are a white plastic now, and they have different screws for the wheel hexes that seem to be much better.
-Mike
Old 02-11-2014, 02:49 AM   #1313
Send a message via Skype™ to martinskarin
You can use the open ball joints instead of the closed ones and it should be fine even with 3mm shim.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 02-11-2014, 03:05 AM   #1314
I wonder why xray bother with the closed ones seeing as they cause such problems?
Old 02-11-2014, 03:38 AM   #1315
Skiddins's Avatar
-Mike
Is it definitely a genuine T4?
Were the white plastic parts on a sprue like the normal black plastic shock parts?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-11-2014, 04:54 AM   #1316
daleburr's Avatar
Skiddins
Mine were white as well, and it came from RCDisco. Think they've made a running change.
They're still moulded.
It does make it easier to build the shocks as you can see dirt/air inside the shocks a lot easier.
Team Xray
Old 02-11-2014, 05:43 AM   #1317
Skiddins's Avatar
I was hoping it was a change to machined nylon pistons instead of items you have to cut out carefully.
I use RSD pistons in mine for that reason.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-11-2014, 08:42 AM   #1318
As far as I can tell, it's genuine. It's got the authenticity cert and the seal on the box and xray written all over all the bags, same plastic as xray parts I've bought in the US, same packed by labels and moisture sheets, perfect fit and finish, etc. But all 3 of my xrays came from that shop, so...
Anyway, the shock parts are still molded. I'm not sure if it's a new mold, though. I haven't compared the sprue. The old mold was one of each piston and the shaft guides per sprue, and you get 4 sprues, right?
-Mike
Old 02-11-2014, 09:00 AM   #1319
Skiddins's Avatar
-Mike
I can't remember exactly but that does sound correct.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-11-2014, 11:13 AM   #1320
are you having to swim home yet? datchet looks horrendous on the news
