Old 02-08-2014, 06:44 AM   #1276
Trader Rating: 57 (100%+)
Put the spacers between the top deck and bulkhead where the 4 screws connect front and rear. You are literally just raising the top deck so it does not touch the existing holders.
PROMODVETTE is offline   Reply With Quote
Old 02-08-2014, 01:51 PM   #1277
aussierevo's Avatar
Trader Rating: 11 (100%+)
ok, thanks for that. I did think it was that simple. Cheers
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 02-08-2014, 05:57 PM   #1278
vabroom's Avatar
Question:
Where are you guys mounting the transponder?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 02-08-2014, 06:01 PM   #1279
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by vabroom View Post
Question:
I mount mine right on top of the servo holder. Perfect spot for the trans and the ESC switch.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-08-2014, 06:48 PM   #1280
+1, although my switch is stuck to the servo, next to the rx.
-Mike
Old 02-08-2014, 07:44 PM   #1281
vabroom's Avatar
Thanks for the ideas, guys.
Old 02-08-2014, 11:46 PM   #1282
Odin544's Avatar
Trader Rating: 93 (100%+)
I've got mine in the front bumper right under the bumper holder.
TriCitiesRC.com
Old 02-09-2014, 12:19 AM   #1283
B00t13g's Avatar
R/C Tech Elite Subscriber
Question:
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-09-2014, 01:34 AM   #1284
Question:
i mount it under my receivr
cheapskate.brok is offline   Reply With Quote
Old 02-09-2014, 03:16 AM   #1285
alloyslash's Avatar
Trader Rating: 19 (100%+)
Question:
I use the RSD bumper brace / Mylaps mount
http://www.reflexracing.net/RSD-Alum...T4_p_1743.html
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 02-09-2014, 04:30 AM   #1286
Hi guys, just mounting up my speed6 body and I am wondering how high the bottom edge of the body should generally be of the ground for asphalt racing with the box setup? I have six at the front currently and 3 at the back which is clearly too low. Should I just raise the whole thing up one hole all round on the body posts? Thanks
Fly'n Fish is offline   Reply With Quote
Old 02-09-2014, 05:34 AM   #1287
Originally Posted by RobS View Post
Got my cars Friday night and built them both yesterday. Builds were awesome! Only problem I had was on one of the kits 3 out of the 4 wheel hex's wouldn't stay on the car. With the screw as tight as I could get it without stripping out the head they still fell off. Not a big deal really as I had extra's anyways but odd none the less. Can't wait to try these bad boys out!
send a mail to xray, i sent one and they request me a video... if like i was the first person to said it to them....
chachotu is offline   Reply With Quote
Old 02-09-2014, 06:55 AM   #1288
The small screws holding the hex on are a bit too long because the threaded portion was not deep enough. Cut 1-2 mm off those screws with a dremel and they will snug up the hex.
Old 02-09-2014, 10:31 AM   #1289
vabroom's Avatar
I was thinking about doing that but couldn't figure out how to rout the wires without moving rubbing against the wires.
Old 02-09-2014, 10:43 AM   #1290
chasingthepack's Avatar
so long as it doesnt touch the ground when you press it down thatll be fine,have you cut it on the legal lines?,i trim the front splitter to about 3mm to get it lower and 10mm forward of the bumper
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Sir Tamiyalot
