Old 01-17-2014, 08:52 AM   #1036
chasingthepack's Avatar
Originally Posted by spencehotbodies View Post
Question
Has any body tried the wish bones plates yet? If so what did you think?
spence,i tried them in dry low/med grip seemed to help at the time with more corner speed in blinky,the following week it was a bit greasier and i had understeer so i took them off and it gave more side bite in the rear and more steering,i think there only for med to high grip,i would run them on carpet,it sharpens up the car,pretty much like having the graphite arms
i was going to get the graphites arms but as i have the plates i wont bother,its easier to take the plates off than change the arms and theres a company out there offering different thicknesses 1mm/1.5mm and 2mm
xray 1.6mm
higher the bite the thicker the plates,thats my theory on it
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-17-2014, 10:47 AM   #1037
spencehotbodies's Avatar
xray 1.6mm
Cool cheers, I'm going to give them a try at the next rug racers.
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 01-17-2014, 12:47 PM   #1038
Odin544's Avatar
Trader Rating: 93 (100%+)
Who makes the different thickness plates?
TriCitiesRC.com
Old 01-17-2014, 01:21 PM   #1039
Roche
nevergiveup is offline   Reply With Quote
Old 01-17-2014, 03:52 PM   #1040
should be worth a couple of tenths a lap if you have a good car to start with,are you using hagbergs set up?
Old 01-17-2014, 04:58 PM   #1041
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Xray (1.6 and 2.0mm)
Roche (1.0, 1.5 and 2.0mm)
Smokem (1.5mm)
They are all different in shapes, not sure about the CF itself.
I am loving the Smokem ones on low grip outdoor asphalt tracks.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-18-2014, 12:19 AM   #1042
Barry_Hughes's Avatar
Smokem (1.5mm)
Thought Xray only did one - the only part number I can find is for the 1.6mm.
I have used them with the kit arms and they seemed to smooth the car out, this was on med grip carpet.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 01-18-2014, 03:43 AM   #1043
Haven't tried hagbergs set up yet, am running Zak's ews set up at the mo. I'm still running the t4 with 14 wishbones. Really like the idea of the plates, I think xray only do one thickness of plate? I know Roche do a few.
Has any one tried hagbergs set up with the ride tyre?
Old 01-18-2014, 03:46 AM   #1044
Barry did you change any thing on your set up when you used the plates?
Old 01-18-2014, 08:54 AM   #1045
Joe Tanto's Avatar
Today I tried my new Xray T4 2014, before this I used to run a T3. I am using stock settings for my T4 from the manual and kit springs. On the whole I found the car good, but the only problem I have is that the steering is to sensitive. Any ideas how I can solve this? I am using Shock oil 35 and diff 1000.
Joe F
Xray T4 2014
Joe Tanto is offline   Reply With Quote
Old 01-18-2014, 09:31 AM   #1046
No, just put the plates on to see if they made a difference, as I said it seemed to just settle the car a bit better and felt smoother so I left them on.
Have got some graphite arms to try so will put them on for the next EWS to see how they feel, as std arms + plates is supposed to be like the graphite arms and all the top guys seem to run graphite.
Built it !
Raced it !
Wrecked it !
Old 01-18-2014, 09:33 AM   #1047
Joe F
most people run thicker rear diff oil 2000cst or 3000cst, have seen some set ups with 5000cst.
Personally I am running 3000cst rear diff, 450 cst oil front & rear and a 1.4 front roll bar
Built it !
Raced it !
Wrecked it !
Old 01-18-2014, 09:55 AM   #1048
found this on red rc
New from Xray are these optional graphite lower arm plates which can easily change the hardness of the whole suspension. With the plates mounted, the arms are stiffer to make the car more stable and easier to drive under high-grip conditions. The plates can be easily mounted/dismounted using only 4 screws. Whether you drive in low or high-traction conditions, with the smart graphite stiffeners you can very quickly adjust your car to suit different conditions. At the beginning of a race event when traction is low, the arms are used without the SFATM graphite stiffeners. When traction increases, the suspension can easily be made stiffer by mounting the SFATM graphite stiffeners for more stability and easier driving characteristics. The graphite stiffeners give the car maximum stability in chicanes and allow for easier and smoother steering.
Old 01-18-2014, 12:50 PM   #1049
they are the 1.6mm ones
Built it !
Raced it !
Wrecked it !
Old 01-18-2014, 01:58 PM   #1050
Default changes
Joe F
if this for running on carpet. Try Zero shims on the steering plate and a 1.3mm rear roll bar. On carpet most people use between 2000 CST and 3000 CST oil in the rear diff depending on grip level. 400cst front shock oil and 400/450 rear shock oil with zero rebound.
matt prigmore is offline   Reply With Quote
