Old 10-05-2013, 12:53 PM   #91
AL1983's Avatar
Post
Originally Posted by Skiddins View Post
I've decided to fit the original style rod ends with the kit ball ends to allow more room between it and the wheel when using a a few shims;
And yes, I have added some Orange bling option parts
What is the part number for the outer rod-ends pictured?
Thx!
Albert
AL1983 is offline   Reply With Quote
Old 10-05-2013, 01:18 PM   #92
Will there be a conversion kit to bring a 2013 to 14 standards, similar to rsd?
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 10-05-2013, 01:27 PM   #93
vabroom's Avatar
They have in past (once or twice, I think) though I don't expect them to, cuts into their optimized profits. lol
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 10-05-2013, 02:17 PM   #94
You should swap your steering links left to right for easier adjustment
Regards,
David
niemand is offline   Reply With Quote
Old 10-05-2013, 03:35 PM   #95
Skiddins's Avatar
Regards,
David
I always mount the links the same way on both sides, so when the car if facing me I can turn the turnbuckles the same direction on both sides to acheive the same result.
i.e. the turnbuckle on the other steering link is also on the left.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-05-2013, 03:54 PM   #96
Didn't know that But it's probably better than my approach of having to look at the threads each time before making an adjustment
I noticed that the setup sheets have an option for graphite suspension arms.
Any thoughts on the difference between graphite suspension arms and the stock ones reinforced by the option carbon plates? (apart from weight and durability)
Regards,
David
Old 10-05-2013, 04:39 PM   #97
Skiddins's Avatar
Regards,
David
Over a year ago I changed to carbon arms but couldn't really tell any difference.
At least now we have this 'plate' option it will be easier to try the changes back to back.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-05-2013, 11:09 PM   #98
xrayracer1's Avatar
Originally Posted by yokemad View Post
Great looking Kit ! I now feel like its time to upgrade my T3 2012 LoL
I think it's time for me to upgrade my T3 2010 lol.
xrayracer1 is offline   Reply With Quote
Old 10-05-2013, 11:26 PM   #99
Bishop's Avatar
Based on the amount of parts they did end up changing, I kind of doubt now they will do any sort of upgrade kit.
I'm still debating with myself weather to keep or sell my original T4 when buying the new T414, you always think it's a trade off on value vs useful spares.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-06-2013, 06:15 AM   #100
NR
NR's Avatar
Trader Rating: 52 (100%+)
Hi Guy's,
Hope you don't mind my free plug, anyone interested in al Xray Australia news and announcements, you can now find out here http://www.facebook.com/xrayaustralia
As for others outside Australia, feel free to like our new page too, I may even convince Alex and other Xray drivers too come along and answer a few questions
Nathan
NR is offline   Reply With Quote
Old 10-06-2013, 06:33 AM   #101
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Why? Do you plan to run more than a 2mm shim on this post? What wheels are you using that would be a clearance issue? I just looked at my T4 with 1.5mm shim with Jaco tires. There is some room to spare. Do you/would you really run a 2.5mm shim there? Or are your wheels the issue?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 10-06-2013, 08:30 AM   #102
syndr0me's Avatar
Trader Rating: 32 (100%+)
I wonder if the T4'14 will need a gear diff up front like the T4 does?
syndr0me is offline   Reply With Quote
Old 10-06-2013, 12:10 PM   #103
Barry_Hughes's Avatar
Snowy.
I am sure Damian will give an answer, but in the UK we run rubber tyres not foams.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 10-06-2013, 12:17 PM   #104
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
He means Jacob rubbers....
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-06-2013, 02:18 PM   #105
Skiddins's Avatar
Snowy.
I plan to be able to run whatever shims I want or need to
With Sorex wheels and 2mm on the outside link my rod ends still show some wear.
On some of the team setup sheets they have used 3mm shims on the outside.
Now I know I can without risk of damage to the wheel.
I also have some RP wheels and tyres which are smaller.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
