Old 01-11-2014, 12:00 PM   #1021
bucknuts's Avatar
Originally Posted by spencehotbodies View Post
Yok on carpet hard to beat.
Volker on carpet hard to beat
bucknuts is offline   Reply With Quote
Old 01-11-2014, 12:57 PM   #1022
JayBee's Avatar
Trader Rating: 31 (100%+)
+1
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-11-2014, 10:45 PM   #1023
millbank's Avatar
Tried using an Xray battery bar before then realised why would i want an extra top deck in my car....
Just tape from then on.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 01-12-2014, 07:35 AM   #1024
Trader Rating: 38 (100%+)
Anyone have a good set-up if I'm going to be racing it in a VTA race series? Thanks.
Breakin2 is offline   Reply With Quote
Old 01-16-2014, 11:36 AM   #1025
Bump from page 3!
-Mike
Old 01-16-2014, 01:25 PM   #1026
Skiddins's Avatar
Originally Posted by grippgoat View Post
Bump from page 3!
-Mike
Just that the T4'14 owners don't have to spend our time on forums asking about the latest 'fix' for an issue
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-16-2014, 01:42 PM   #1027
I must say you got a point there. when I switched from a other car to XRay2012
I have plenty time to do other things, this is a boring situation and also for the wear of the drive train refilling shocks and diffs.
You can only help others with your finding for a set-up.
I hope Olly Jeffries find something special or a miracle or something similar.
eded1 is offline   Reply With Quote
Old 01-16-2014, 03:57 PM   #1028
Send a message via AIM to Jonesy112
I would start with the kit setup, but with 2.7 springs up front, .5 raised rear arm mounts and .5 in to take a bit of rear toe out. That will be a good starting point for it
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 01-17-2014, 01:34 AM   #1029
Hi all, im new on this forum. Till a couple off years ago i used to drive 1/10 nitro on road buth i quite racing and sold all my stuff.
Now i want to start racing again and want to buy 2014 t4.
Because i have no Spares or other equipement at all in need your help what to buy.
I thinki i need:
Body ( Mazda 6 speed? )
Pinion gears ( witch dp and witch tooth )
Spur gears ( same )
Springs ( witch ? )
Extra option parts?
Thank you and sorry for my bad english.
Neem is offline   Reply With Quote
Old 01-17-2014, 02:06 AM   #1030
Trader Rating: 57 (100%+)
First you need to tell what surface/size of track and motor you will run.
PROMODVETTE is offline   Reply With Quote
Old 01-17-2014, 03:48 AM   #1031
Sorry,
I Will drive stock classe. With a speedpassion 13,5t with Max ratio of 1:4,5. Most off time outdoor asphalt track.
And also at a carpet indoor track
Is the spur gear that comes with the kit 48dp or 64dp?
Old 01-17-2014, 04:18 AM   #1032
spencehotbodies's Avatar
Question
Has any body tried the wish bones plates yet? If so what did you think?
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 01-17-2014, 07:42 AM   #1033
Trader Rating: 20 (100%+)
Originally Posted by Neem View Post
Sorry,
The Kit comes with 48dp 84t spur gear. For 4.5 fdr I would toss in a 64dp 100t spur with a 42t pinion.
The Mazdaspeed6 body should be a safe starting point.
Because you are running both asphalt and carpet I would get the full range of xray springs for the car. Two sets each to keep your tuning window open. That may seem overkill but asphalt and carpet, low or high grip can use very different springs. There are other spring kits available but I would stick with xray springs in order to be able to relate to most setups that people post.
I wouldn't add any option parts to the car out of the box. Just drive it and save the money for later when you have more experience with it to decide if you need anything else on it.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 01-17-2014, 08:01 AM   #1034
rosko's Avatar
Question
I have on highbite they work really good frnt and rear with the post no layshaft screws and on low to medium they work well on just the front. Plates on froont and rear on medium bites track took away to much traction imo
rosko is offline   Reply With Quote
Old 01-17-2014, 08:44 AM   #1035
cwoods34's Avatar
Agreed..... It makes a big difference on high bite, especially if you aren't running graphite arms.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
