Xray T4'14
#1006
I've found that the RSD battery holders are awesome if your battery is completely flat at the top. Some batteries (like the SMCs) have the +/- ports slightly recessed and lower than the rest of the battery. It's hard to get that working bc you can only lower the holders so much bc of the L-battery brackets.
#1007
Tip: initially I was hesitant to use battery holders rather than tape because of the uneven flex battery braces are known to cause. (Think of the old school XRAY ones.) The solution is to carefully shim for both the fore and aft as well as torsional flex. You want to make sure when the chassis flexes torsionally it feels similar in both directions. This means the battery holders should not dig into the battery, but rather smoothly hold it in place. Try it for yourself, and you will see what I mean.
I love the RSD battery holders. They even run terrific in modified where chassis flex is critical as a tuning option. The Awesomatix cars also use similar holders to great effect.
#1010
Got mine from EMR Factory.
#1014
Top three fastest laps in DHI practice (seeded);
Alexander Hagberg 12.122 - Xray
Adrien Berntsen - 12.135 - Xray (I think?)
Ronald Volker --- 12.138 - Yokomo
Although Volker has still managed the best three consecutive laps in both rounds and of course these times mean nothing.
Will be interesting to see what happens in the main quali's which I believe start shortly.
http://www.myrcm.ch/dk/odense/201401...dif/index.html
#1015
Can't wait for my T4 2014 to arrive!!
JF
JF
#1016
#1017
#1018
rd 3,hagbergs getting quicker
Pos Nr Driver
1 1 Völker Ronald 25 5:06.013 11.719
2 4 Kutvonen Viljami 25 5:11.211 12.199
3 5 Hagberg Alexander 25 5:11.430 12.214
4 2 Rheinard Marc 25 5:11.906 12.215
5 6 Fischer Marc 24 5:03.068 12.337
6 8 Graversen Steen 24 5:05.305 12.438
7 9 Ratheisky Jan 24 5:06.322 12.427
8 10 Hudy Martin 24 5:07.843 12.238
9 7 Hornum Patrick 24 5:09.731 12.453
10 3 Berntsen Adrian 2 0:30.093 12.904
Pos Nr Driver
#1020
Pos Nr Driver
Pos Nr Driver
