Old 12-31-2013, 01:44 PM   #976
Originally Posted by syndr0me View Post
I dunno, says "syndr0me" in my browser. My name is Adam.
I'm no setup expert, I'm sure some mixer will jump in and tell me why this is wrong. But that said, my experience is that it allows the car to roll around more and helps get some steering from the middle of the corner out. I'm trying to fight off an army of fast Awesomatix cars that are stunningly fast through the corners, so it's a constant battle trying to get out of the middle of the corner faster. I think it makes it feel a little lazy in fast transitions though, and can be prone to traction rolling depending on the grip.
I feel like my '14, much like the cars it replaced, has chronic understeer in the middle of the turns. Maybe it's okay compared to other belt drive cars out there, but in the slower classes, the shaft is destroying us.
I agreed this car suffers badly with mid corner understeer, Mine looks like it stops mid corner
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 12-31-2013, 01:51 PM   #977
Originally Posted by FLAT OUT View Post
Hi, is that your real name on that setup sheet ????
It said "grippgoat" when I looked at it. I think they've got a bug.
-Mike
Old 12-31-2013, 02:19 PM   #978
-Mike
Lol yeah when I looked at it my name was showing on the setup I thought there can't be to of us both racing Rc
Old 01-04-2014, 12:45 AM   #979
Default T14-14 stafford setup
Hi
I know have my T4-14 build and good to go I was just wondering if someone a has a base setup for stafford indoor that I could start with for next Sunday. I am running in the 17.5T blinky class. I have seen one of the team driver setups fir sorex tyres and was going to start there.
andrewd is offline   Reply With Quote
Old 01-04-2014, 04:11 AM   #980
chasingthepack's Avatar
Originally Posted by andrewd View Post
Hi
Originally Posted by Skiddins
I don't know anything about Stafford's indoor track, but Hagbergs Sorex setup is a very good starting point.
It works at Newbury
heres the set up
http://www.petitrc.com/reglages/xray...icars20131026/
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-04-2014, 08:45 AM   #981
Barry_Hughes's Avatar
If you open a set up on the Xray site using the left button of the two options i.e. not clicking the pdf file, it inserts your Xray forum username in the set up sheet
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 01-04-2014, 05:59 PM   #982
Trader Rating: 70 (100%+)
Is anyone running a hex through the bottom shock mounts? This is my first TC and coming from offroad, this seems weird.
If you are running a hex, what is the size/type of the hex.
Krafcik is offline   Reply With Quote
Old 01-04-2014, 07:33 PM   #983
ngo8's Avatar
Send a message via ICQ to ngo8
3.0 mm top and bottom .
ngo8 is offline   Reply With Quote
Old 01-04-2014, 07:37 PM   #984
edit - looks like 3 x 10 button works well
Old 01-04-2014, 07:40 PM   #985
Trader Rating: 13 (100%+)
The screw size that fits into the ball is 2mm. I'm sure some people have run a screw through the bottom, but I've never had a problem with the stock setup.
Sean B. is offline   Reply With Quote
Old 01-04-2014, 07:52 PM   #986
i was talking where the shock mounts to the arm - above poster is right it's 3mm
Old 01-04-2014, 08:45 PM   #987
Yes, sorry I mistyped
What are you going to do up top then? Longer screw with a nut?
Old 01-04-2014, 08:53 PM   #988
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Using the 3mm set screw style shock mounting to the arm works great, recommend using a "little" loctite for security. I too thought this was odd, coming from an offroad background, but I've never experienced it coming loose.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 01-05-2014, 03:26 PM   #989
daleburr's Avatar
If you use a screw straight into the arm, sooner or later the arm will strip from regular removal of the shock.
The xray system is fantastic and like it for a reason.
Team Xray
Old 01-05-2014, 04:14 PM   #990
Why would it strip? We run outdoor like this and don't have arms stripping.
