Old 12-30-2013, 02:46 PM   #946
Trader Rating: 13 (100%+)
Yes, with spool or diff.
Sean B. is offline   Reply With Quote
Old 12-30-2013, 03:01 PM   #947
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I would think u have a pin not fitting property or a bad spot on one of them . does it do it more one way than then other ?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-30-2013, 03:19 PM   #948
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
It does it the same in both directions. It's a new car with no time on it's own wheels so there's no wear. If there's a way to get it out without the ECS than i'll check it but I knew it as soon as I saw it from my T3 days. The wheel chatters and hops a little at full lock.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 12-30-2013, 03:25 PM   #949
Odin544's Avatar
Trader Rating: 93 (100%+)
Its no different on the T4 or any TC that I've owned. Some are a little worse than others.
TriCitiesRC.com
Old 12-30-2013, 03:31 PM   #950
Skiddins's Avatar
Originally Posted by ToysRUsKid View Post
I finished building my car and held it up to test the motor. that works fine but I noticed when i turn the wheels at full speed, i start to get chatter. Is that common or did i build something wrong?
All TC's have 'spool chatter' on full lock.
Changing to ECS driveshafts will prevent it, but it's nothing to worry about.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-30-2013, 05:02 PM   #951
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Jon Williams View Post
Uh oh. What are you thinking, Syn?
On the subject of the top deck/layshaft screws: I ran without all four this past weekend at Horsham with a few small tweaks to my regular setup. As was discussed previously in the thread it gives the car a wider tuning window: sort of like an oversized tennis racket with a larger sweet spot. I very much liked it with the crazy traction we had at the track. The car was excellent all day long and along with Fairtrace smashed the track record in qualifying this past weekend.
Also ran the lower suspension braces (F&R). I like them as well. The car feels more direct and aggressive, but not in a 'loose' sort of way. I guess 'more direct' is the easiest way to describe how they feel to me.
Have yet to try the top deck post. I'm siding with Skiddins' perception on my prediction, but will try it out in practice on Saturday.
Suspension braces? Which ones are you referring to? The arm plates??
You have your setup on xray? Id be interested in seeing what it looks like compared to what Ive been running.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 12-30-2013, 06:26 PM   #952
Jon Williams's Avatar
R/C Tech Elite Subscriber
Arm plates, yup. Corrected.
Jon Williams is offline   Reply With Quote
Old 12-30-2013, 06:56 PM   #953
emacrimes's Avatar
Are the ECS front shafts really needed?
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 12-30-2013, 07:54 PM   #954
ToysRUsKid's Avatar
Good question, doesn't sound like they are necessary.
Old 12-30-2013, 08:35 PM   #955
Odin544's Avatar
From what I am told with a gear diff they aren't a must have but with the spool they help the most. I have the RSD ones and the Xray ones. If you are on a budget go with the RSD ones. $50 for the pair.
TriCitiesRC.com
Old 12-30-2013, 08:49 PM   #956
I'm tired of running Sweep tires. I've been getting them for about $20 a set which is nice, but I think they just suck so bad it's not worth it anymore.
Running indoor carpet, medium grip. Any suggestions?
I would like to run Jacos, but sounds like they won't be around anymore. Also have my eye on Schumacher Sorex, but $$$$.
I'm just hard to please huh
Old 12-30-2013, 09:05 PM   #957
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Ride tires seem to be the tire to have, but for some reason no track wants to run them. I'm sure its to support US shops, but you almost have to buy a set of tires every race day. Ride's last 3 or 4 race days.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS / EA MOTORSPORTS
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 12-30-2013, 09:06 PM   #958
erchn's Avatar
Have you tried Powers tires? The 32s and 34s are pretty darn good, great wear.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 12-30-2013, 10:00 PM   #959
syndr0me's Avatar
Trader Rating: 32 (100%+)
What have you heard about Jaco? It seems like availability always lags between IIC and Snowbirds and then picks up again.
We've had pretty good luck with Sweeps here lately. We've been trying them since Jacos aren't available and nats is on Sweeps. They do seem to slow down a bit as they heat up and the run goes on, but the improved grip is really welcome on club traction, and they last quite a while.
I'd love to try a side of the RIDE tires being used at ETS. Isn't the US importer for RIDE Thunder Power? They would have to be in steady supply to be taken seriously.
syndr0me is offline   Reply With Quote
Old 12-30-2013, 10:40 PM   #960
Well, I heard from a guy who heard from a guy about the Jacos. You know how that goes, but he says it's a pretty trusted source I guess. We'll see. If it is true, we definitely need another tire besides Sweep.
I'm probly being too critical of Sweeps, but I'm just ready to try something else. I've been running them since I started running TC again last winter. They do feel inconsistent, and from others I've talked to, it's not their favorite tire at all.
I'd like to try the Rides as well but it would be cool to get them from somewhere other than RCMart.
