Old 12-29-2013, 01:46 PM   #931
Originally Posted by RSCosworth View Post
Why do people insist on setting up their car with, and running with, "flex"?
If your chassis is flexing surely you are taking something away from your shocks, springs and tyres? It can't be making those components work to their full potential?
Good question that bothers me too. Full size race cars live and die by their rigidity. I think what you give up on un-dampened flexing/springing you gain on controlability. TC is scale in name only, almost nothing scales from full size (the wheelbase does). The simple fact is that flex works!
Fly'n Fish is offline   Reply With Quote
Old 12-29-2013, 04:44 PM   #932
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Yea our crummy 1/10scale shocks r nothing like the full size brothers...
hell think of it we r running the 1/10 cars at 40mph easy in scale terms they would be going 400mph..
we r able to double and sometimes tripple our full scale comparisons. So with that said we have to be doing something right .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-29-2013, 04:45 PM   #933
DP.
Justin & Matt Lyons
a800s sanwa m12s
Old 12-29-2013, 10:16 PM   #934
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Running more flex in the cars not only helps make traction to our cars.
We dont run same type of rubber content on our cars like real cars.
The biggest difference in flex chassis opposed to a stiff chassis setup is if your setup if off a little or a lot with with a flex chassis it still is very drivable.
With a stiff chassis, bad setups are definately magnified!
my opinion..
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 12-30-2013, 01:34 AM   #935
morgoth's Avatar
I've been running the top deck post without the layshaft screws (top deck shimmed up 1mm) for the past month and the car has great forward traction. But I feel my car is lazy on direction changes. Anyone else that shares this thought? And what have you done to fix this? Or is everybody running the car with the layshaft screws in the car?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-30-2013, 02:28 AM   #936
The center topdeck mount should make the car react faster to direction change.
Stevenkoiter is offline   Reply With Quote
Old 12-30-2013, 05:56 AM   #937
Skiddins's Avatar
While it did seem to react more and gave more rounded steering mid corner, as the grip came up I didn't like it as it became more difficult to drive.
This was on a medium sized carpet track, but with 180 type corners, not longer 'flowing' corners.
Certainly something to try at your track, but I think most of the time I'll probably be tuning using the layshaft screws.
When I used it I didn't have the topdeck spaced up at all.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 12-30-2013, 11:10 AM   #938
syndr0me's Avatar
Trader Rating: 32 (100%+)
Juraj Hudy needs a special project...
syndr0me is offline   Reply With Quote
Old 12-30-2013, 12:26 PM   #939
Jon Williams's Avatar
R/C Tech Elite Subscriber
Uh oh. What are you thinking, Syn?
On the subject of the top deck/layshaft screws: I ran without all four this past weekend at Horsham with a few small tweaks to my regular setup. As was discussed previously in the thread it gives the car a wider tuning window: sort of like an oversized tennis racket with a larger sweet spot. I very much liked it with the crazy traction we had at the track. The car was excellent all day long and along with Fairtrace smashed the track record in qualifying this past weekend.
Also ran the lower suspension arm plates (F&R). I like them as well. The car feels more direct and aggressive, but not in a 'loose' sort of way. I guess 'more direct' is the easiest way to describe how they feel to me.
Have yet to try the top deck post. I'm siding with Skiddins' perception on my prediction, but will try it out in practice on Saturday.
Jon Williams is offline   Reply With Quote
Old 12-30-2013, 12:40 PM   #940
my opinion..
^^This. My understanding is that there is quite a lot of flex in less sophisticated full scale race scars (think karts, lower-end stock car applications). Even in the top level race cars there is *some* chassis flex. While not ideal it's a pragmatic approach to tuning when you don't have a team of engineers to perfect your setups.
Again, after some reading on the topic it appears racers use this to broaden the tuning sweet spot. Similar concept to ours.
Old 12-30-2013, 12:59 PM   #941
syndr0me's Avatar
I was thinking maybe a conversion kit for the T4'14 that gives it 4 wheel steering.
Old 12-30-2013, 01:08 PM   #942
Like the Awesomatix dynamic toe-in/toe-out?
Old 12-30-2013, 03:07 PM   #943
ToysRUsKid's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to ToysRUsKid
I finished building my car and held it up to test the motor. that works fine but I noticed when i turn the wheels at full speed, i start to get chatter. Is that common or did i build something wrong?
Dorian Tisdale - Professional RC Driver Wannabe
RC America \ DeSoto Racing \ XRay \ Novarossi
www.tsrcar.com \ Red Mosquito raceway \ www.racersoftoledo.com \ www.midwestseries.com
ToysRUsKid is offline   Reply With Quote
Old 12-30-2013, 03:23 PM   #944
Trader Rating: 13 (100%+)
You must not have front ECS driveshafts?
Sean B. is offline   Reply With Quote
Old 12-30-2013, 03:35 PM   #945
ToysRUsKid's Avatar
Nope, stock build. I didn't know they were still necessary since the change from T3 to T4. Is that what you're running with the diff up front?
SEO by vBSEO 3.5.0
