Old 12-28-2013, 01:04 PM   #916
Originally Posted by chasingthepack View Post
ask at the track,why try to guess,which is all anyone on here would be doing
Really?
Madman1 is offline   Reply With Quote
Old 12-28-2013, 04:29 PM   #917
chasingthepack's Avatar
Originally Posted by Madman1 View Post
Really?
ok you could narrow it down abit,what size track are you racing on?what esc do you use?what motor?how much timing?what car?
as you can see its hard to just pull an fdr from a hat
but at the end of the day the best answer will come from someone at the same track with the same motor
different motors react differently and require there own type of fdr,a long fast track will want a low fdr but a small track will want a higher fdr,its all down to motor temp,you could easily blow a motor in 3 minutes flat with the wrong fdr hence why i say ask at the track,$140 is at stake if you get it wrong,and thats only if the blown motor doesn't take out the esc as well
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-28-2013, 05:49 PM   #918
R/C Tech Elite Subscriber
Originally Posted by shaun207 View Post
cheers gareth , it is gareth isn't it !??
if it is ill see ya at cwic
Yup. I'll be there.
Miniripper is offline   Reply With Quote
Old 12-28-2013, 06:45 PM   #919
Is the Composite front spool ok for a 4.0T motor on asphalt?
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Old 12-28-2013, 06:46 PM   #920
Why do people insist on setting up their car with, and running with, "flex"?
If your chassis is flexing surely you are taking something away from your shocks, springs and tyres? It can't be making those components work to their full potential?
RSCosworth is offline   Reply With Quote
Old 12-28-2013, 06:54 PM   #921
Bigz84's Avatar
Trader Rating: 15 (100%+)
running those at Toledo will be just fine. how are you liking running indoors?
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 12-28-2013, 07:16 PM   #922
Hey what's up man. It's pretty fun, I prefer outdoor but it's a nice fix for onroad during the winter ..t's kind of far to go every weekend. Going to start running some 1/8th buggy at that new track the clubhouse. I'll probably go to Toledo once every couple weeks though.
Thinking about building a T4 for the summer and see which I like more the ERYX or the T4. The front composite spool kind of threw me off, sounds great as long as it can hold up to the power of a 4.0-4.5
Old 12-28-2013, 08:14 PM   #923
cwoods34's Avatar
I've noticed a bit of wear on the outdrives, but I've never had one break just from usage. They'll last a long time
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-29-2013, 12:09 AM   #924
Has anyone played with which balls on the rear arm you connect the swaybar to?
-Mike
Old 12-29-2013, 04:54 AM   #925
MrRolla's Avatar
Trader Rating: 29 (100%+)
I havent used them but 1 step either side softens or stiffen the sway bar by half a step Ive read
MrRolla is offline   Reply With Quote
Old 12-29-2013, 08:04 AM   #926
tak4's Avatar
Prepared a new body for the final race of 2013.
Forgot today was Sunday and missed the race completely. I need to find a 9-5 job with proper weekends...
Nova powered MP9 Tki3
Hobbywing powered Kyosho MP9e (Tki3)
Orion powered Xray T4'14
Driven with Sanwa M12
tak4 is offline   Reply With Quote
Old 12-29-2013, 09:13 AM   #927
Who's chasingthepack,are you sure you know what your talking about????
Tam417x is offline   Reply With Quote
Old 12-29-2013, 12:30 PM   #928
yup,(i must change it to caught the pack)unless you know different,i dont see anyone else posting a responce,maybe you can help him burn up a motor
Old 12-29-2013, 12:41 PM   #929
i had the same discussion at the track today and quite a few were running with either 2 or 4 screws removed,i had a stiffener fitted to the rear of the top deck and all screws in place and posted the fastest lap in blinky and finished 1st and 2nd in the a finals,ive tried a few conditions and not once have i found it helps,i think itll help more in mod but for 13.5boosted and 17.5 blinky it hasnt helped me,not saying it doesnt help others
Old 12-29-2013, 01:06 PM   #930
erchn's Avatar
Flex is mostly about widening the setup window, by either making the car easier to drive (to a point) or generating traction. Especially on an outdoor track the conditions of the track can change pretty dramatically between races. While it's likely true that a perfect setup can be found and can be faster with much less flex, you'll also miss the setup window much easier.
Case in point, when I drove the first Awesomatix car, a car that was originally designed for foam tires and as such was quite stiff, the car was either unbelievable great or it was pretty terrible, very rarely in between. Since then, they've gone to a much more flexible setup, in most cases, and have found consistency. Anecdotal, yes, but this is essentially an opinion forum after all.
Ethan
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
SEO by vBSEO 3.5.0
