Old 12-18-2013, 05:41 PM   #886
CristianTabush's Avatar
Trader Rating: 11 (100%+)
If you use the Spec R Spur gear spacer, you can get away with Kimbrough spurs. They are a bit of a tight fit on the e-clip, but they work.
Also, If you can get a hold of RW/Xenon/ Core RC spurs, they will fit.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 12-18-2013, 06:12 PM   #887
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
If PRS spurs were in stock anywhere their what to run in stock anyways . the narrow teeth might not be recommended for mod tho
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-19-2013, 12:43 AM   #888
Chuggz's Avatar
I am running serpent spur on mine direct fit and wide teeth
Chuggz is offline   Reply With Quote
Old 12-19-2013, 08:43 AM   #889
chasingthepack's Avatar
Originally Posted by CristianTabush View Post
Yes, the effect is very similar in 17.5. I typically run the same set-up in 17.5 and mod. I actually like to develop set-ups with slower motors because it is easier to identify problems when your car is going slower, and you are looking for corner speed to get fast laps.
It usually ends up translating well into modified, but I am not a crazy over powered mod driver. I like just the right amount of power as I feel I can push the car harder and be more consistent with it. Indoors, I hardly ever run anything faster than a 5.5. If I was running more power, I would probably change set-up a bit.
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-19-2013, 12:25 PM   #890
spencehotbodies's Avatar
Hello
Am in the market for a 14, any body know the best place?
Cheers
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 12-19-2013, 01:01 PM   #891
Thanks, guys. Looks like Serpent is probably the easiest to come by.
AMain has both Yokomo/Panaracer and ARC spurs in 96T, though. Any idea about those?
-Mike
Old 12-19-2013, 01:18 PM   #892
The Panaracer should work. I just compared it to an XRAY one on the wall.
Old 12-19-2013, 04:09 PM   #893
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
So do the lay shaft mounts use same bearings as original or smaller ?
I would like a set that's been lowered 1mm (material taken from the bottom ) but the motor mount holes would have to be redrilled also
The material is removed from the top and yes a smaller bearing Is used so that the layshaft is in the same spot. We tested with a normal size bearing and lowering the layshaft, but the rear belt rubs on the motor mount
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-20-2013, 06:19 AM   #894
Send a message via AIM to Jonesy112
The panaracer 96t is all that I use for stock. Fits very well.
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 12-21-2013, 08:06 PM   #895
Default Spool outdrives
Hi
Just changed to xray a month ago , what a fantastic car. Improoved my 5 min race time by around 6 sec. So far the car is a tank . Nothing broken.
But what are you guys running as spool outdrives? Stock plastic ones or hudy steel with blades or aftermarket parts????
Thanks in advance
Michael
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 12-21-2013, 08:44 PM   #896
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by johnsen-dk View Post
Hi
Thanks in advance
Michael
Hi Michael,
I too just changed and had my first run last night. Very happy with change.
Spool cups:
Smokem Racing - but you must use TRF 44mm DCJ (super hard wearing and no blade required)
Roche - uses kit DCJ, Team Magic DCJ, or Roche DCJ (super hard wearing and no blade required)
HTH.
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 12-21-2013, 09:15 PM   #897
I'm still running kit outdrives on mine, and run spec-r plastic ones before on my 2013, including mod on asphalt and carpet. Haven't broken one yet, but I've replaced one of the spec-r ones that started binding after it was worn. I don't crash too often, though.
-Mike
Old 12-21-2013, 11:13 PM   #898
Trader Rating: 27 (100%+)
I'm using Spec-R spring steel outdrives. Don't require blades and have held up pretty well in stoic blinky.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 12-22-2013, 12:41 AM   #899
Hi again
I changed the kit ones to xray replacement. And it made steering super smooth. The kit ones had sign of wear . I race mod on small carpet. Funny that No-one use hudy steel outdrives.
Team Xray-shop.dk
Old 12-23-2013, 03:27 AM   #900
nerdling's Avatar
Hi
Thanks in advance
Michael
I've run the Hudy Alloy/Steel out drives as well as the kit plastic ones. I've never had a problem with all three types. You need to replace the plastic ones as they will wear out over time, on the upside the plastics will break if you jam a front wheel protecting the rest of the drive line.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
