Old 12-18-2013, 09:44 AM   #871
chasingthepack's Avatar
in the wet my cars rear is too stuck without removing any screws for flex,id like to loosen up the rear to get more steering as it understeers badly though the chicane
does ackerman affect low grip levels,as i have arm sweep i havn't got any shims,should i add some to get the wheels turning more parallel?
heres my set up
http://forum.teamxray.com/xform/inde...&setup=t4_2014
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-18-2013, 09:48 AM   #872
RedBullFiXX's Avatar
R/C Tech Elite Subscriber
Trader Rating: 34 (100%+)
heres my set up
Less rear toe-in perhaps ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
RedBullFiXX is offline   Reply With Quote
Old 12-18-2013, 09:54 AM   #873
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Does anyone have or make a RF mount split or solid ?
Rcamerica has them on back order from xray . even there Jan shipment don't have any included i was told . i need a pair !
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-18-2013, 10:50 AM   #874
CristianTabush's Avatar
Trader Rating: 11 (100%+)
Originally Posted by Skiddins View Post
I assume no.2 is 'No layshaft screws with post
fixed it! I am on a roll lately with this proofreading ish...
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-18-2013, 11:01 AM   #875
morgoth's Avatar
During practice yesterday I hit a car in the chicane that spun out. It was a very hard hit but the 1.6mm pin in my ECS shaft broke but I couldn't notice it. While going full throttle on the straight, the shaft popped out the barrel and the car was pulling to the left while I was overtaking someone and I was a half meter from the wall. The car pulled into the wall and the topdeck snapped in 2.
Rebuild it today and all other pieces seem fine including the bulkheads. I hope the chassis isn't damaged. At least there's no visible damage to it.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-18-2013, 11:21 AM   #876
B00t13g's Avatar
I have a set of split mounts I can send you, new in package.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-18-2013, 01:00 PM   #877
thats what i had in mind next time out,as per the sheet,forgot the link
Old 12-18-2013, 01:05 PM   #878
Originally Posted by CristianTabush View Post
With mod, I run the post 99% of the time. This os my breakdown:
1.no layshaft screws no post:
-maximum rear flex: makes the car more stuck in low grip conditions, good for non prepped surfaces. On high grip carpet can make the car over rotate from too much rear flex. The car tends to want to keep rolling in the middle of a corner, less on power traction, more off power traction. Great forward bite. Car can wander a bit if the oil and springs are not right.
2.no layshaft screws no post:
-high rear flex. More on power steering than regular T4 set up, car rolls well. Good compromise between flex and steering. More steering than regular set up on high bite. More off power traction in low bite, but less on power traction.
Car can wander a bit if oil and springs are not right.
With the lowered layshaft mount I feel like you can go up 50-100 both f/r to gain stability lost due to the increased flex.
would this work for blinky 17.5 ? or what would you change ?
Old 12-18-2013, 01:08 PM   #879
pantomime time
OH NO YOU HAVEN'T!!
Old 12-18-2013, 01:22 PM   #880
Yes, the effect is very similar in 17.5. I typically run the same set-up in 17.5 and mod. I actually like to develop set-ups with slower motors because it is easier to identify problems when your car is going slower, and you are looking for corner speed to get fast laps.
It usually ends up translating well into modified, but I am not a crazy over powered mod driver. I like just the right amount of power as I feel I can push the car harder and be more consistent with it. Indoors, I hardly ever run anything faster than a 5.5. If I was running more power, I would probably change set-up a bit.
Old 12-18-2013, 02:19 PM   #881
emacrimes's Avatar
Hi, im new to electric on road and got my self a t4 '14.
I would like to know what would be good upgrades, things that you guys really recommend also what can i change in the cars setup to race on asphalt ad parking lots (i know sukcs for the chassis but we dont have any carpet tracks in Costa Rica).
Any suggestion will be appreciated.
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 12-18-2013, 03:40 PM   #882
Trader Rating: 13 (100%+)
Anyone know the scoop on the new white shock pistons?
New material I'm assuming.
Sean B. is offline   Reply With Quote
Old 12-18-2013, 03:54 PM   #883
Moderator
Clegg's Avatar
machined delrin like the Tamiya ones?
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-18-2013, 04:05 PM   #884
No, they are still on a tree.
Old 12-18-2013, 05:27 PM   #885
Originally Posted by grippgoat View Post
What are my options for a non-offset 64p / 96t spur that will fit the T4 properly?
-Mike
Bump for an answer.
I don't really like offset spurs. It seems like it either puts the pinion into the belt or into the motor mount (or closer than I'd like, anyway). The kit 84T/48P spur is non-offset, and the pinion goes in much nicer. But it looks like that's the only non-offset spur that Xray makes.
-Mike
