Old 12-14-2013, 12:03 PM   #841
ATLASCOPCO's Avatar
Originally Posted by jlfx car audio View Post
Yes l. There r 5 different inserts .
(*1)
(1)
(*.5)
(.5)
And they can be flipped 4 ways giving u 17 different settings per mount
And 289 possibilities for adjustment to that arm
Thank you for going to the trouble to explain that for me
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 12-14-2013, 12:15 PM   #842
ATLASCOPCO's Avatar
Originally Posted by ATLASCOPCO View Post
[ATTACH]u[/ATTACH]
So the f/f has not been filled in
This could be 0.5 or 1?
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-14-2013, 12:52 PM   #843
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
More than likely since they haven't been filled in it could be the center dot (•)
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-14-2013, 01:44 PM   #844
ATLASCOPCO's Avatar
More than likely since they haven't been filled in it could be the center dot ()
It marked as having the outer centre filled in but the .5 or 1 not filled in
This is all new to me sorry 😃👍
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-15-2013, 01:06 AM   #845
millbank's Avatar
3 chassis's snapped at the bumper at our club. Bumper brace needed to make this car safe for the masses
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 12-15-2013, 02:15 AM   #846
MrRolla's Avatar
Trader Rating: 29 (100%+)
Thats been a well known fact since the release of the T413. Annoying that Xray refuse to include it with the 14 as standard though.
MrRolla is offline   Reply With Quote
Old 12-15-2013, 04:35 AM   #847
cwoods34's Avatar
A quick and cheap solution is to flip over the upper bumper plastic piece and put 4-5mm of shims under it where it bolts to the lower piece (so that the plastic touches the bulkhead). You may need to use longer screws. It isn't the prettiest option but I've ran mine like that for awhile.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-15-2013, 04:47 AM   #848
MrRolla's Avatar
The mount that Xray sell is $5, hardly gonna break the bank on $500 touring car
Old 12-15-2013, 05:43 AM   #849
Skiddins's Avatar
This is all new to me sorry ����
You're correct, that part of that sheet is a mistake.
To be anything other than the centre dot of those diagrams, it MUST be either 0.5 or 1 blocks.
As you only usually have 0.5 difference in the blocks to make arm sweep, I think the FF blocks should be 0.5's
I take it that's Hagberg's Sorex sheet? If so, everyone I know has taken it as 0.5 blocks.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-15-2013, 09:51 AM   #850
morgoth's Avatar
I tried hagbergs ETS setup and his setup from the charity race in Italy with ride Rex 30 tires (new control tire for us).
The ETS setup was super aggressive with tons of steering, but it wasn't stable in a few parts of the track. Mainly in the chicane it was bad. Softer front oil and a harder rear roll bar would have probably solved that, but I didn't tried that since I also wanted to test the other setup.
The other one is basically the same as his sorex setup and was super stable. In some parts of the track it pushed a little during mid corner. This setup was the easiest to drive but I'm not sure if it was faster.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-15-2013, 09:53 AM   #851
ATLASCOPCO's Avatar
Skiddins
Cheers Damian
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-15-2013, 11:52 AM   #852
Will61's Avatar
R/C Tech Elite Subscriber
picking up your car from the front bumper is what stresses the front of the chassis. All the weight of the car is on those 3 screws. Mine cracked in my hand i felt it, i did not hit anything hard my first 3 runs.
I have a real bad habit of picking up the car from the front bumper, it has stopped
Still running the same chassis and i have had some serious Tbone incidents, the chassis still lives. I used shims to raise the plastic like the above post, works like a charm. I'm not impressed with the quality of screws used on this kit, it's to bad the quality is slipping. The car though on track AMAZING :P
Will61 is offline   Reply With Quote
Old 12-15-2013, 04:32 PM   #853
Jerz616's Avatar
Trader Rating: 49 (100%+)
I have always felt their screws were pretty bad. I have started using the 12.9 from www.hexcrews.com on the bottom of my last 3 kits and have had no stripped screws since. Prior to using these I have always had stripped screws and needed to drill them out.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-15-2013, 07:00 PM   #854
Dog Bone's Avatar
Hey Will, what setup are you using on your car? Wayne's? You car looked pretty dialed at the race weekend before last....
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 12-16-2013, 01:39 AM   #855
Skiddins's Avatar
Use Torx screws, problems solved
Xray X12 2017
Xray X1'16
RCDisco.co.uk
