Old 12-05-2013, 12:54 AM   #766
B00t13g's Avatar
R/C Tech Elite Subscriber
Originally Posted by grippgoat View Post
Make sure the wheels aren't rubbing on the outer front camber link cup. On my sweep qts32 on the new wheels, it rubs quite badly with 2mm on the outside.
-Mike
Not that you asked, but the solution to that is to use the open ball cups that are used on the toe links. I've been running 2mm shims on the outer with sweep 28s and haven't had any rubbing.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-05-2013, 07:04 AM   #767
Right On the other hand... I suffered some damage today. Went sideways into a steel bar. Never thought it'd be a hazard!
Xray T4'14-20131205_145030-small-.jpg   Xray T4'14-20131205_165025-small-.jpg   Xray T4'14-20131205_145655-small-.jpg
cheapskate.brok is offline   Reply With Quote
Old 12-05-2013, 11:38 AM   #768
metalnut's Avatar
Trader Rating: 36 (100%+)
Ouch!
- Ricky Bobby
Old 12-05-2013, 11:44 PM   #769
I can't really decide if I made progress with my setup this weekend. I ran Q1 with a basic setup based on my previous race. That used RSD Orange/Pink F/R with medium camber links, the rest kit. Didn't do well, but didn't over-drive it.
Q2 I dropped the front roll center by 0.5mm. Hated that. The car wouldn't get into the corners at all. It was a bit faster on fast lap, but less consistent, and not confidence-inspiring.
For the mains, I punted on a setup. Went back to kit 2.5 springs F/R, with rear laid down a hole. Returned RR block to center for 0.5mm anti-dive, widened rear pins by 0.5mm, and added 0.5mm front droop. In practice before mains, with no sauce, it felt pretty well behaved with pretty decent balance, but was hard to tell how fast it was. In the main, it was slower than I was hoping, but I could be pretty aggressive, and all in all it was a decent run. The car is slower than I want it to be, but with the setup that's on it now, I feel like it doesn't have any glaringly bad behavior, and it'll just be a matter of fine-tuning several things to get it tightened up.
Setup attached.
Video:
+ YouTube Video
I'm the darker yellow car starting in 5th. The driving looks pretty sloppy, but I was actually being reasonably restrained. Some of that is feeling out the new setup. Some of it is getting thrown out of rhythm by cars in front. And a lot of it is that the car was just floaty / greasy feeling. Tires are possibly going off the cliff, too.
My next steps will be thicker rear diff (to try and address the on-power steering), thicker rear shocks (probably AE 40f/37.5r erring on the thick side), and 0.5mm less droop all around. Might try 3.5* rear toe. Hopefully that'll lock the car in a little more overall.
This video shows the sloppiness wasn't all driver:
http://www.youtube.com/watch?v=tVDcNr_rG9A
Win from pole in our 25.5 class.
-Mike
EDIT: Link to higher-rez image of setup on my SkyDrive:
https://skydrive.live.com/redir?resi...t=photo%2c.png
ALSO EDIT: Suggestions welcome.
Old 12-06-2013, 12:57 AM   #770
morgoth's Avatar
Setup attached.
Video:
+ YouTube Video
-Mike
For more incorner steering, you can use a short rear link. Also I don't like the car with 1mm shims or less on the rear bulkhead. I prefer 1.5mm-2.0mm depending on the track/tires. Going lower than 1.5mm makes the car very aggressive and it feels like the rear is loose. It's okay to run this in stock classes, but in modified it takes too much stability away imo. You should try that and see if you like that better
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-06-2013, 01:52 AM   #771
Setup attached.
Video:
+ YouTube Video
-Mike
You have been going in the direction that I went through to get a car that feels fast but still easy/consistent to drive so you can push it. A couple of suggestions that may help you but obviously carpet/driving style etc. may mean it doesn't work for you but worth trying...
Unless your track is very high grip I would go back to the shorter upper roll centre.
Lay the front shocks down to second hole from the inside.
Add the 2mm shim at the top of the front shocks.
These changes aim to get the car feeling consistent.
Then to get the car to finish the corner better;
Rear diff to 2k possibly 3k depending on your driving style
1.3 rear roll bar
As I said, just some things to try and this is effectively moving you towards the Hagberg carpet setup which is worth getting.
I don't know what front anti dive will do or the theory on it - I have always run hinge pins level front and rear on the T4.
Good luck
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Serpent UK | Modeltune
scoyle is offline   Reply With Quote
Old 12-06-2013, 02:10 AM   #772
B00t13g's Avatar
I would use a shorter rear link, thicker rear diff oil, kit hinge pin locations and a 1.3 rear bar. This is what I'm running and have been very happy with it day in and day out even on two different layouts.
http://forum.teamxray.com/xform/inde...&setup=t4_2014
Mackenzie Meyercord
Old 12-06-2013, 02:37 AM   #773
Skiddins's Avatar
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 12-06-2013, 02:37 AM   #774
Skiddins's Avatar
Setup attached.
Video:
+ YouTube Video
-Mike
The white car from the front of this video was running Hagbergs Sorex setup with the exception of 400 front oil and 450 rear;
+ YouTube Video
Admittedly this was on Sorex 28 tyres, but the setup might be useful as we don't have amazing grip either.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 12-06-2013, 10:17 AM   #775
chasingthepack's Avatar
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-06-2013, 10:43 AM   #776
hahaha!
cyclonetog is offline   Reply With Quote
Old 12-06-2013, 10:48 AM   #777
sgp-chris's Avatar
Hi guys,
I'm considering buying this kit. I haven't raced onroad in 5 or 6 years, but I have a couple of tracks real close to me, and it would be nice to have something to race during the winter.
Does the T4'14 require any upgrades out the box. I'm thinking outdrives, chassis brace, cvd's, etc. I might aswell build it right the first time
Its only gonna be used for some stock class club racing, nothing major. It's all about having something fun to do on sundays
Hotbodies D812 | Schumacher Mi5
sgp-chris is offline   Reply With Quote
Old 12-06-2013, 11:15 AM   #778
Skiddins's Avatar
Originally Posted by sgp-chris View Post
Hi guys,
I ran mine 'out of the box' with kit setup for a few weeks and it was fine, until I bent a driveshaft
Other than a few spares, no upgrades needed.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 12-06-2013, 11:18 AM   #779
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Nothing is needed to be competitive out of the box . low profile servo at blenky ESC and 300-330g battery , and motor .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-06-2013, 11:29 AM   #780
Skiddins's Avatar
Originally Posted by chasingthepack View Post
are you sure?
Yes
Xray X12 2016
Xray X1'16
RCDisco.co.uk
SEO by vBSEO 3.5.0
