Old 12-04-2013, 01:45 AM   #751
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Roche DCJ... Perfect
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-04-2013, 04:30 AM   #752
daleburr's Avatar
Do they use a narrower bearing on the inside, or a standard one?
Team Xray
Old 12-04-2013, 05:50 AM   #753
MrRolla's Avatar
Narrow
MrRolla is offline   Reply With Quote
Old 12-04-2013, 07:31 AM   #754
Osiris 75's Avatar
Trader Rating: 17 (100%+)
What's the first 3 things you change on carpet when traction comes up?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 12-04-2013, 09:24 AM   #755
Rear diff, Shock Oil and camber
Breezy1 is offline   Reply With Quote
Old 12-04-2013, 09:32 AM   #756
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
First camber .
2nd lengthen camber links
3rd go to high role blocks ()
If Ur still traction rolling with
0 front camber
Long links
High role blocks ()
Soft springs
Med\soft oils
...... Glue sidewall or slow down .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-04-2013, 03:07 PM   #757
RobS's Avatar
I go about it differently depending on the situation.
First- Traction compound application (less on front).
Second- Thin shim on front axles to widen out the front width (especially in traction rolling circumstances).
Third- Camber links, lengthen as stated above.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 12-04-2013, 04:45 PM   #758
I always dope tires same tho I might do front and rear at different duration . but I can't do of the tire consistently every time it always puttles on bottom of tire. Wheel spacers work tho in some cases
Justin & Matt Lyons
a800s sanwa m12s
Old 12-04-2013, 04:53 PM   #759
Chris Adams's Avatar
Chris, check your pm.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is online now   Reply With Quote
Old 12-04-2013, 05:54 PM   #760
Trader Rating: 13 (100%+)
Hey guys has anyone used the MR. Roche slick marc ceramic bearings? Or should I just stick with the Xray bearings?
Thanks in advanced
Link:
http://beamcat.com/collections/ball-...c-bearing-sets
Pulpetti is offline   Reply With Quote
Old 12-04-2013, 07:17 PM   #761
Khador12's Avatar
Originally Posted by chasingthepack View Post
so what did you all do to get the rear end the way you liked ,anyone fancy posting set up sheets for comparison?
I started with the kit carpet setup and the rear was crazy loose. After a few changes this is what I came up with, now it is more stable and easy to drive. Setup Here
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 12-04-2013, 08:08 PM   #762
Originally Posted by Khador12 View Post
I started with the kit carpet setup and the rear was crazy loose. After a few changes this is what I came up with, now it is more stable and easy to drive. Setup here
That link doesn't appear to have worked.
-Mike
Old 12-04-2013, 08:13 PM   #763
Jerz616's Avatar
Trader Rating: 49 (100%+)
https://rs823p1.rapidshare.com/cgi-b...ovo1.pdf&bin=1
Try it this way.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-04-2013, 08:20 PM   #764
Khador12's Avatar
Thank you
Billy Stewart
Xray T4 17
Old 12-04-2013, 11:52 PM   #765
Originally Posted by Jerz616 View Post
Make sure the wheels aren't rubbing on the outer front camber link cup. On my sweep qts32 on the new wheels, it rubs quite badly with 2mm on the outside.
-Mike
