Old 11-29-2013, 04:24 AM   #736
tak4's Avatar
Hey guys,
Am wondering what springs are everyone using? I have the Sakura spring set and the Hot Bodies set but was wondering what other spring options are there?
Nova powered MP9 Tki3
Hobbywing powered Kyosho MP9e (Tki3)
Orion powered Xray T4'14
Driven with Sanwa M12
tak4 is offline   Reply With Quote
Old 11-29-2013, 04:54 AM   #737
morgoth's Avatar
Originally Posted by cwoods34 View Post
You can take out some rear toe. I've noticed that adds a good amount of rotation to the car.
Also, instead of the hard progressive springs, you could try 2.7s front and rear.
I tried 2.5 of toe in instead of 3, but the car was too twitchy on power. I'll try the 2.7s springs this weekend.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 11-29-2013, 08:32 AM   #738
erchn's Avatar
Originally Posted by morgoth View Post
I'm looking for more cornerspeed on carpet with CPX tires. The rearend of my T4 '14 isn't free enough to go fast around the corners. The track is quite technical so it needs a good amount of rotation.
Here's my current setup: http://forum.teamxray.com/xform/inde...&setup=t4_2014
I think running higher roll centers in the rear and running the 1.3 rear bar is probably keeping the rear of the car from rolling, and in turn not giving you the loss of lateral grip you're looking for.
I think I'd probably try going back to a 1.2 rear bar, and if it's loose on power, try 400 cst rear oil.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 11-29-2013, 11:37 PM   #739
B00t13g's Avatar
R/C Tech Elite Subscriber
Originally Posted by tak4 View Post
Hey guys,
2.3, 2.5 and 2.5-2.8 are the normal ones. Other than the factory xray springs I would recommend RSD.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 11-30-2013, 12:38 AM   #740
millbank's Avatar
Now using hagberg's sorex set up with 3k diff oil and 2mm top deck and the car is on rails. Since putting this set up on the car i've not lost a club night. Looking forward to cwic's next sunday.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 11-30-2013, 02:31 PM   #741
edhchoe's Avatar
Trader Rating: 41 (100%+)
I have been enjoying the T4 for the last 8 months or so racing it in a VTA type class.
The only complaint has been how it is not very easy to access the grub screw on the pinion. An extra hole in the chassis at the correct location would be nice.
For T4 2014, I would have to buy optional rear pieces to change the rear toe whereas on my T4 2013 I can use different shims, right?
edhchoe is offline   Reply With Quote
Old 11-30-2013, 02:48 PM   #742
I just finished putting it together...waiting on electronics to complete as a VTA build...
Assembly was a non issue,very nice indeed...
But I've found that with HPI,5 spoke wheels,the wheels make contact with the lower shock cup at full lock...I expect no worries as it sounds as if I will have more than enough steering without having to go anywhere near full lock...but I have "+" wheel hexs on the way in any case...
And open stye rod ends on the upper links will be a must...
On another note,this is only the second gear diff I have used..the first in a AE TC6.1...this is not a burn on associated,but the difference is night and day...this Xray diff borders on the smoothness of a ball diff...me like a lot...!
"well the marshall didn't put it on it's lid"
RB6...Orion R10
TLR 22sct...Orion R10
AE tc6.1...Orion R10
brwn bggr is offline   Reply With Quote
Old 12-01-2013, 01:24 PM   #743
metalnut's Avatar
Trader Rating: 36 (100%+)
Good thread, this car is putting my wallet in danger.
- Ricky Bobby
Old 12-03-2013, 12:40 PM   #744
chasingthepack's Avatar
so what did you all do to get the rear end the way you liked ,anyone fancy posting set up sheets for comparison?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-03-2013, 01:55 PM   #745
hotrod1933's Avatar
All parts to change toe come with kit. Little plastic inserts in alum blocks.
slip the rear block off swap inserts and re fit.
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 12-03-2013, 05:40 PM   #746
Anyone know the best online shop to buy t4 14 a main is out thanks
J-money is offline   Reply With Quote
Old 12-03-2013, 05:44 PM   #747
edhchoe's Avatar
Rcmart has them for 517 shipped on their website and on eBay. There is a used one on this forum in for sale section with some hopups for $475 shipped.
Old 12-03-2013, 06:38 PM   #748
Cool thanks for the help
Old 12-03-2013, 07:57 PM   #749
C.Smith's Avatar
Tried a front diff with 1,000,000 cst. The car was amazing!
Mugen USA. Reds Racing Engines Speed World Raceway & Hobbies.KO Propo ,Matrix Tires,Colors by Chris. My wifes patience
C.Smith is offline   Reply With Quote
Old 12-04-2013, 12:18 AM   #750
morgoth's Avatar
Thanks! Drove the car again yesterday at an other track, but they have the same carpet and the car was great by narrowing RR with 0.5 (2.5 toe), 2 camber front and rear and 50mm rear ECS shafts. There's still room for improvements, but a least it turnings better.
The only thing that bothers me a lot with this car is that my front ECS shafts with 2.0mm pins break all the time. I have 6 meetings on this car and broke already 2 of them. And both broke while driving and not from a crashing
I'm going to repair once more and sell them.
I order DCJ shafts from reflex racing and I hope they are better.
The front belt snapped at the end of the straight. Last year I drove a whole season indoor with the same belts :/
