Old 11-27-2013, 02:41 PM   #721
Originally Posted by Skiddins View Post
Sounds like you need to try an evening with each of the two types of srtup to see who's suits you better.
The tricky thing is lack of track time: one or two green-track practice runs, 2 qualifiers, and a main once every two weeks. If I'm lucky I can sometimes sneak in an additional short run between rounds.
The other tricky thing is lack of parts to properly replicate the team driver setups. I've got some springs and the top deck brace on the way. But I'm trying to keep my parts box for this car pretty empty. There's so many ways to achieve lap time, there's usually another way to get the same result. For example, Paul used 2-hole front arms, and non-standard wheel hexes.
-Mike
Old 11-27-2013, 04:53 PM   #722
Skiddins's Avatar
-Mike
Sounds like you'll need to 'approximate' each drivers settings, perhaps do one drivers setup each day and see which seems to suit you better.
If not, fill out an Xray setup sheet and post a link here so guys can help.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-28-2013, 05:39 AM   #723
Trader Rating: 9 (80%+)
Hey im looking at getting an xray springs which ones would be best suited for asphalt. Also which size roll bars Too front & rear (Asphalt Only) thanks
Dan-Dan Team-X is offline   Reply With Quote
Old 11-28-2013, 05:51 AM   #724
Skiddins's Avatar
2.3, 2.5 2.7 & 2.9's
Or Reflex Racings spring sets.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-28-2013, 07:14 AM   #725
alloyslash's Avatar
R/C Tech Elite Subscriber
Trader Rating: 19 (100%+)
+1
Reflex has a set of springs custom engineered towards asphalt racing for the T4 shocks. They also have full sets of SpecR sway bars priced very reasonable.
http://www.reflexracing.net/RSD-20mm...ir_p_1735.html
http://www.reflexracing.net/SPR024-R...mm_p_1599.html
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 11-28-2013, 08:01 AM   #726
morgoth's Avatar
I'm looking for more cornerspeed on carpet with CPX tires. The rearend of my T4 '14 isn't free enough to go fast around the corners. The track is quite technical so it needs a good amount of rotation.
Here's my current setup: http://forum.teamxray.com/xform/inde...&setup=t4_2014
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 11-28-2013, 09:27 AM   #727
Trader Rating: 20 (100%+)
I think it's too generic of a question really. Every track will be different and your setup and driving style may be different too. I've found that depending on the track I like either the 2.3's all around or the 2.5-2.8's all around. I run the stock roll bars.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 11-28-2013, 11:35 AM   #728
chasingthepack's Avatar
spring set 2.3's to 2.8's and roll bars 1.5 s and 1.3's should cover everything front and rear
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-28-2013, 11:38 AM   #729
morgoth's Avatar
A 1.3mm front roll bar is also used a lot on asphalt
Old 11-28-2013, 02:59 PM   #730
Do the spec-r bars fit the t4 properly? Or are they more for the t3?
-Mike
Old 11-28-2013, 05:58 PM   #731
Chuggz's Avatar
Trader Rating: 11 (100%+)
Are most you asphalt guys running the no lay shaft screws?
Or a thicker front shock oil?
Chuggz is offline   Reply With Quote
Old 11-28-2013, 11:19 PM   #732
nerdling's Avatar
-Mike
T3 bars will not fit a T4.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 11-28-2013, 11:28 PM   #733
Trader Rating: 57 (100%+)
The spec-r bars for the spec-r car will also not fit. Top is front bottom is rear (spec-r is same shape f/r)
PROMODVETTE is offline   Reply With Quote
Old 11-28-2013, 11:42 PM   #734
CristianTabush's Avatar
The bars will actually work, you just have to use sway bar collars to center them on the bulkheads. They are a good, much lower cost alternative to the T4 pieces.
We are working on a sway bar set, should be out soon and won't break the bank.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-29-2013, 03:38 AM   #735
cwoods34's Avatar
You can take out some rear toe. I've noticed that adds a good amount of rotation to the car.
Also, instead of the hard progressive springs, you could try 2.7s front and rear.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
