Old 11-23-2013, 06:18 PM   #706
Skiddins's Avatar
Originally Posted by morgoth View Post
This is my current setup on CPX tires. The track is pretty tight and technical and I need a little more steering. The steering is close to what I want in the beginning of the run, but at the end the front tires overheat and I have to slow too much to make the car turn.
What could I do to get more steering? I'm thing of going to 2.5 rear toe instead of 3, but that change looks a bit drastical to me. Isn't it? I think the car will be hard to drive after that change. Tomorrow is Q4 and Q5 so I can't practice a lot :-(
Whatever your setup is, are you sure you're overheating the fronts?
Have you measured their temps after a run?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-23-2013, 06:52 PM   #707
5tylez's Avatar
Originally Posted by Warren Weaver View Post
Yes
Sweet, saves me from buying the cso v2 upgrade.
5tylez is offline   Reply With Quote
Old 11-23-2013, 07:43 PM   #708
chiefj48's Avatar
Originally Posted by Sean B. View Post
Hits the chassis, or top plate?
What gearing?
Chassis
No gear on motor
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, RocheUSA, SerpentUSA, AwesomatixUSA, ValkariaRC, Trinity, DiscountRCStore, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 11-23-2013, 08:21 PM   #709
B00t13g's Avatar
R/C Tech Elite Subscriber
Originally Posted by chiefj48 View Post
Chassis
No gear on motor
That was a common problem with the kill shots.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 11-23-2013, 08:36 PM   #710
chiefj48's Avatar
So how do I solve it????
chiefj48
Old 11-23-2013, 08:46 PM   #711
B00t13g's Avatar
Replace the front mounting plate or call trinity. They sent me a few right when the motor came out to correct that issue.
Mackenzie Meyercord
Old 11-23-2013, 08:56 PM   #712
chiefj48's Avatar
Thank u!!!
chiefj48
Old 11-23-2013, 11:14 PM   #713
morgoth's Avatar
Originally Posted by chasingthepack View Post
you forgot to post a link
*facepalm* Here it is: http://cl.ly/SdgW
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 11-24-2013, 12:08 AM   #714
porsche928gs's Avatar
Link: http://cl.ly/SdgW
Change rear diff oil to 2000. Go to 3000 only if it's high bite traction. Reduce rear droop. If using droop gauge, remember that higher number on the gauge is less droop. I also think you may add a little more droop on the front.
AKA Gilberto Santos
Banana Raceway
Yokomo BD7 2014-2015-2016, Yokomo BD8, 2018 BD8, YR10f, YZ2-CA -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 11-24-2013, 06:30 AM   #715
Send a message via AIM to Matt W
Default Tamiya springs
Has anyone tried using the short Tamiya springs, I was wondering how they compare to the Xray ones?
Matt W is offline   Reply With Quote
Old 11-24-2013, 12:40 PM   #716
morgoth's Avatar
Thanks for your tips, but I just read them when I came home.
I tried 2.5 rear toe in Q4. That gave more steering but was hard to drive, mainly onpower during the first minute.
In Q5 I raised the rear inside hingepins with the 1 inserts and the car was dialed. More steering, but more preditable and stable onpower than with the 2.5 rear toe. And the front tires didn't overheat anymore. The car was very constant during the finals.
Old 11-24-2013, 03:44 PM   #717
cwoods34's Avatar
The problem is they don't fit well.... If you "force" them onto the shock collar and use the older (smaller) XRAY spring perch they fit. They work fine, BUT.... It's so much easier to just use XRAY ones
If you insist on trying them, white front/blue rear is a good starting point
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-25-2013, 03:07 AM   #718
Hey All
Anyone have a problem mounting motor in chassis??
I'm using a kill shot motor and it hits the chassis.
My killsnot is tight against the lower deck too.
Smartypants is offline   Reply With Quote
Old 11-27-2013, 01:27 PM   #719
Bump from deep in page 2.
I'm hoping I can get my car working well this weekend (Mod TC on carpet). It's been pretty frustrating with my two outings so far. :/ The first outing wasn't actually toooo bad, but I had a lot of binding in the rear (rushed build) and the wrong shock pistons. And I was on the back foot all night from a late arrival to the race and a stressful day.
My biggest problem last time out was a severe lack of on-power steering, so I just couldn't finish the corner and get on the power. Less front droop made the car too unpredictable in the tight sections getting on/off power, though. So overall it led to me over-driving trying to force the car to do the lap times, which never ends well. I might try going up from 2K in the rear diff, but a bit of anti-squat has crossed my mind, too.
I think I'm going to start with the setup one of the locals gave me that's got more Paul-ish and Hagberg-ian elements to it, and see if I can get to a happier place. It's pretty strange how different Paul's and Hagberg's IIC setups were in pretty significant areas, yet they were still so similar on pace.
-Mike
Old 11-27-2013, 03:13 PM   #720
Skiddins's Avatar
-Mike
Sounds like you need to try an evening with each of the two types of srtup to see who's suits you better.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
