Old 11-17-2013, 04:38 PM   #661
aussierevo's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Mikkel_R View Post
Ran the car for the last few weeks now and I think im finally getting to grips with it. Been trying different things and finally got my base car setup. Have to running the car a fair bit stiffer than stock and dial out alot of initial steering. For the first time last night I felt I could drive it how I wanted and was very happy, never really got the same out of last years car.
Would you mind sharing what changes you have made. I'm running outdoors asphalt and would like take away some of that initial steering which I believe is giving me a car that is a little taily early in the run.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 11-17-2013, 05:23 PM   #662
chasingthepack's Avatar
leave the steering youll need it later,widen the rear track by 0.5 mm 2.7 springs 400 oil and a 1.3 rear roll bar,3mm over ride height fr and 3,5mm rear,youll love it
i also run 0.5 of front arm sweep
today it started damp and the car was planted,as the grip came up the car just got better and better
on carpet 2.6 fr and 2.5 r worked on med grip
and as said underneath drop to a 1mm rear inner link shim
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-17-2013, 05:54 PM   #663
tpczx6's Avatar
Default Timezone GP
This was my 1st Carpet race in 2 years with a TC
just got done building the 2014 t4 and use EA setup from Snowbirds for Oil,Spring,Camber link set up put the middle dot on the arm hangers
I did go down one step on spring as thinking we will not have as much grip as Snowbirds so a 2.3 rear and 2.6 front 350 oil
car was good all weekend only took out the 2mm shim inboard rear and put in a 1mm shim
Q5 for A main with a 3rd place finish.
Car is good out of the box
i will post my setup when I can get to the t4 14 sheet
Tim
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 11-17-2013, 06:14 PM   #664
alloyslash's Avatar
R/C Tech Elite Subscriber
Trader Rating: 19 (100%+)
Skiddins, in the pics of your T4'14, it looks like your front belt is orange, is it?
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 11-17-2013, 06:18 PM   #665
and dont laugh its a floro highlight pen
Old 11-17-2013, 06:34 PM   #666
aussierevo's Avatar
thanks for sharing this information. I'll give those changes a go.
Cheers
Speed Passion F1.
Old 11-17-2013, 07:13 PM   #667
nccattu's Avatar
Default A video of the Xray T4 2014 spec
I shot this video today at Ho-b Max RC Park in Durham NC. The winner was Anthony Saunders with his Brand New 2014 Spec Xray T4. He let me drive his car after the race and this car is very very good!!! Hope everyone enjoys the video.
http://www.youtube.com/watch?v=a_SRf...ature=youtu.be
nccattu is offline   Reply With Quote
Old 11-17-2013, 08:06 PM   #668
Khador12's Avatar
Last night was the first outings for the T4 14 on low to med. traction carpet. I started out with the kit carpet set up and it was loose. Change to 400cst front shock oil, lowered the rear roll center .5 at the blocks, added center stand off, removed upper screws from layshaft mount and changed rear tou to 2.5. After these changes the car was on rails. The corner speed was awsome!
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 11-18-2013, 03:50 AM   #669
Skiddins's Avatar
Yes
NO... it's a Sharpie paint pen
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-18-2013, 01:19 PM   #670
Mikkel_R's Avatar
My set up so for is for medium grip carpet so cant say it will work on asphalt,
Ride height 5.2 mm front and rear
Camber links as per kit
4 degrees caster
Camber 1.5 degrees front and rear (if you want more rear grip try 2 degrees)
6mm droop front and 5mm on the rear with chassis sat on 10mm blocks
Front roll centre 1mm higher than kit and rear standard
450cst Core oil front and rear with 4 x 1.1mm pistons with 0 rebound and foam inserts
Kit shock positions
Rear toe 3 degrees front 0.5 degrees
Front roll bar 1.4mm ( if you want less front end try 1.6mm) rear 1.2mm
Front spool rear diff 1000cst rear diff in low position and front in high position
All screws in layshaft mount
Standard wheel base setting
Front springs xray 2.9 and rear xray 2.7
Body shell (which has one of the biggest effects ive found) PROTOFORM Mazda speed 6 whi his mounted in the stock postion as is the rear wing
Sorex 28jb tyres using full additive front and rear for 20mins with LRP carpet grip
Again if you need less front end put less additive on front tyres
Mikkel_R is offline   Reply With Quote
Old 11-18-2013, 01:56 PM   #671
Send a message via AIM to Matt W
Default Front wheelbase
Hi,
Has anyone tried shortening the front wheelbase on the t4 14. I was wondering what this would do to the handling?
Matt W is offline   Reply With Quote
Old 11-18-2013, 02:00 PM   #672
Originally Posted by King of B Main View Post
Originally Posted by niemand View Post
I gotta say that mine is a quite a bit tail happy.
That's on very high traction carpet only on power.
Other than that I couldn't be much happier with the car so far.
If anyone finds a cure for the tailhappy behaviour I would like to hear it
Regards,
David
I know when I had that problem with T4 I raised the inner camberlinks up in the rear and the problem went away.
Hi,
its been a while, but i got around to testing on that track again.
I tried all sorts of things to get the rear end planted none succeeded, at last a new set of tires was the cure. Seems as if i got a bad set before
Now I've got a bit of an understeer problem especially mid corner.
Here's what I ended up with:
Everthing carpet base setup except for
Carbon stiffeners
Topdeck post
0mm front inner camber links
1mm rear inner camber links
2k diff oil
low diff and spool position
The track is high traction and really tight and the car is super easy to drive but just not fast enough because it lacks steering and therefore cornerspeed.
Suggestions would be highly appreciated. I already tried every possible inner camberlinkheigt combination which had only a small effect.
Maybe I'll try higher rear RC and harder rear antirollbar next time.
Also remind me what does armsweep do?
Regards,
David
niemand is offline   Reply With Quote
Old 11-18-2013, 02:09 PM   #673
Hi,
Carbon stiffeners
Topdeck post
2k diff oil
Regards,
David
arm sweep will help your situation as it gives more mid and exit,and with the slightly shorter wheel base it gives more turn in,use 0 ackerman shims with arm sweep to keep it the same as if you hadn,t i used a 0.5 center line to the inner on the fr,and +1 on the 1.3 rear roll bar,how much rear toe are you running,on high grip you shouldn't need much,2.5 maybe?
and i can highly recommend widening the rear by 0.5mm
Old 11-18-2013, 02:17 PM   #674
Thanks for the advice.
3 degrees atm.
I never found less rear toe to make me faster, only made my car harder to drive whenever i tested it, but i admittedly never tried it in such high grip conditions.
I guess I'll add arm sweep and toe in to my list then
There are two high speed left corners on the track and my chassis scrubs on the track, so i would also like to try anti dive, but that would act against the arm sweep right?
Regards, David
Old 11-18-2013, 02:32 PM   #675
3 degrees atm.
Regards, David
no it would give a little more initial which will help,anti dive i havn't tried yet as i have enough steering for current cold conditions
but leave that and try widening the rear by 0.5 which gives 3.25 rear toe,on ashphalt im having good results,which also works for me on carpet
the reason for the reduced rear toe would give more overall steering and help it to rotate more
if the chassis is scrubbing raise it 0.4 mm in the rear and 0.2 front
