Old 11-14-2013, 03:46 PM   #646
millbank's Avatar
Can anyone tell me why you would run ecs driveshafts in the rear?
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 11-14-2013, 03:54 PM   #647
daleburr's Avatar
Originally Posted by Barry_Hughes View Post
Hi Eric
looking at your setup for the IIC did you really run with rear eccentric bushings with one on the inside and one on the outside as per the set up sheet?
Looks like an error in the PDF - the online version looks more sensible.
Team Xray
Old 11-14-2013, 04:02 PM   #648
daleburr's Avatar
If you're very, very rich and need to spend a lot of money on driveshafts?
And also to get a bit more steering. But mostly just to burn cash.
Team Xray
Old 11-14-2013, 04:03 PM   #649
chasingthepack's Avatar
Hagberg's response to running ecs in the rear
The ECS shaft doesn't bind up the suspension as much during cornering which allows the rear to work more freely. The rotation and on-power steering will be increased. Forward traction will be decreased, also as a result of the larger rotating mass on the rear axle.
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-14-2013, 04:05 PM   #650
i just posted the sales pitch above lol
Old 11-14-2013, 04:18 PM   #651
syndr0me's Avatar
Trader Rating: 32 (100%+)
Because you hate yourself. It feels like ish.
syndr0me is offline   Reply With Quote
Old 11-14-2013, 06:08 PM   #652
Skiddins's Avatar
Originally Posted by Matt W View Post
Hi,
I've noticed that the front ball cups on the outer turnbuckle gets very close to the inner wheel, almost touching in places. Can you use the flatter ball cups like on the steering turnbuckles or is there not as much movement in these?
Here you go Matt
Originally Posted by Skiddins View Post
This is the clearance with my rod ends;
Completed at last;
Using the lower hole in the servo saver I get 24-25deg steering on both sides, despite the fact I had to increase the EPA to increase the motion.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-15-2013, 12:22 AM   #653
millbank's Avatar
Thanks, i've got an old set of 50mm ones so i'll fit them as per Hagberg's sorex set up
Old 11-15-2013, 04:58 AM   #654
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Anyone got a extra set of RF mounts ? I will buy or replace them soon as they restock at rc america .
Pm me if u can let them go
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-15-2013, 06:10 AM   #655
RC MARKET's Avatar
Trader Rating: 12 (100%+)
ARENA had 1.6mm upper deck
Old 11-15-2013, 04:49 PM   #656
im really liking my 14,first time out on carpet,d final,2nd time out c final and tonight i made 3rd in the b (which was 11th overall,8 driver finals)and then won it,really starting getting to grips with the tight and technical carpet layouts at last,i would still like to get a bit more side bite from the rear but at least this week it was drivable
roll on next week,see if i can keep the momentum going i might just see the a
Old 11-16-2013, 07:45 PM   #657
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Questions?? Shock oil?.....
Hello, I run the Losi shock oils and have just about every weight there is..... Can someone show me the chart of Hudy shock oil in comparison to the weights used..... Like Hudy 600 would be what in wt.?...... Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 11-17-2013, 08:00 AM   #658
Regional Moderator
CarbonJoe's Avatar
Alex - Get the attachment in this post:
Comparison chart for losi shock oil to associated shock oil
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-17-2013, 10:11 AM   #659
b_recliner's Avatar
R/C Tech Elite Subscriber
Trader Rating: 22 (100%+)
very useful....thank u for posting that
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-17-2013, 03:51 PM   #660
Mikkel_R's Avatar
Ran the car for the last few weeks now and I think im finally getting to grips with it. Been trying different things and finally got my base car setup. Have to running the car a fair bit stiffer than stock and dial out alot of initial steering. For the first time last night I felt I could drive it how I wanted and was very happy, never really got the same out of last years car.
Mikkel_R is offline   Reply With Quote
