Old 11-12-2013, 09:26 AM   #631
CristianTabush's Avatar
Trader Rating: 11 (100%+)
Originally Posted by KZsolt36 View Post
Hi
Can you tell me witch XRAY T4 springs similar to the Yokomo blue spring in hardness and characteristic?
At my local track many guys use the Yokomo blue all around for LRP CPX
Thank you!
KZsolt
The closest in rate would be Xray 2.5. The Yoke blue is a 14.2lb spring. The 2.5 is like 14.3.
The springs are very different though. Also keep in mind the XRAY has the front lower arm shock hole much closer. Together than cars like the Yokomo which would make the front softer.
Personally I like XRAY 2.5 and 2.6 on our carpet track, that is when I am. Not using RSD springs.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-12-2013, 11:01 AM   #632
RC MARKET's Avatar
Trader Rating: 12 (100%+)
New Option Parts
Xray T4'14-xr-302169.jpg   Xray T4'14-xr-302190.jpg   Xray T4'14-xr-303169.jpg   Xray T4'14-xr-303190.jpg
Old 11-12-2013, 11:08 AM   #633
Thanks and yes, the comparison seems to be difficult with the lower shock tower
KZsolt36 is offline   Reply With Quote
Old 11-12-2013, 01:44 PM   #634
chasingthepack's Avatar
have you ever tried the 2.5/2.8 progressives on carpet?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-12-2013, 03:50 PM   #635
cwoods34's Avatar
I've ran 2.7 front/2.5-2.8 rear and had good results. They can work well on the front too depending on how you drive the car..... I noticed that the car set well into the turn but had a midcorner push! This was going from 2.7/2.5-2.8 to the 2.5-2.8 all around with roughly the same setup.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-12-2013, 05:00 PM   #636
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Just an FYI My IIC Setup is now posted on the Xray web page.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-12-2013, 05:21 PM   #637
Trader Rating: 57 (100%+)
Thanks Eric!
PROMODVETTE is offline   Reply With Quote
Old 11-12-2013, 09:55 PM   #638
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Are the 14 graphite arms measured the same as the regular graphite arms, or is the only purpose for them to bolt the on the carbon fiber stiffeners?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS / EA MOTORSPORTS
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 11-13-2013, 07:03 AM   #639
Chris Adams's Avatar
The rears are the same, the fronts are slightly different. The fronts have 2mm of extra material at the center of the arm so they should fit the T4 but you wont be able to adjust wheel base.
TEXASEOS.net, SpeedzoneUSA, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2016
Chris Adams is offline   Reply With Quote
Old 11-13-2013, 10:39 AM   #640
And if you're looking at fitting older graphite arms to a '14, you just have to add 2mm extra shims behind the front arm.
-Mike
Old 11-13-2013, 12:13 PM   #641
Send a message via AIM to Matt W
Default Ball cups rubbing
Hi,
I've noticed that the front ball cups on the outer turnbuckle gets very close to the inner wheel, almost touching in places. Can you use the flatter ball cups like on the steering turnbuckles or is there not as much movement in these?
Matt W is offline   Reply With Quote
Old 11-13-2013, 12:16 PM   #642
Osiris 75's Avatar
Originally Posted by Matt W View Post
Hi,
Yes, I think I saw someone using the flatter ball cups, so it should work.
Chris Kemper
Old 11-13-2013, 01:32 PM   #643
Clint161's Avatar
If you use the standard ball cups and just file off the extra material needed to clear the wheel you should end up with a stronger set up
Clint161 is offline   Reply With Quote
Old 11-14-2013, 12:27 AM   #644
nerdling's Avatar
It does.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 11-14-2013, 11:50 AM   #645
Barry_Hughes's Avatar
Hi Eric
looking at your setup for the IIC did you really run with rear eccentric bushings with one on the inside and one on the outside as per the set up sheet?
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
