Old 11-09-2013, 09:05 PM   #616
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
Default Hadberg setup
anyone know where I can find Hadbergs sorex setup ?
King of B Main is online now   Reply With Quote
Old 11-09-2013, 09:53 PM   #617
B00t13g's Avatar
R/C Tech Elite Subscriber
His Facebook.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 11-10-2013, 04:07 AM   #618
chasingthepack's Avatar
here ya go,i tried this set up and found the rear loose,change the droop settings and itll be better,but for medium grip i would try at least 3deg of rear toe in
http://www.petitrc.com/reglages/xray...icars20131026/
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-11-2013, 09:43 AM   #619
Skiddins's Avatar
Can someone confirm how the kit track width compares to the T4'13, in overall width at each end and the distance between the pivot pins (across the chassis, not the inner pivot pin to outer pin).
My old T4 now has an RX4 conversion so I can't measure it at all.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 11-11-2013, 10:03 AM   #620
erchn's Avatar
Skiddins
I think you're asking for '13 measurements. If so, to the center of the pins with stock settings:
Front: 45.3mm
Rear front, measured just behind arm holder: 40mm
Rear rear: measured just in ahead of arm holder: 43.3mm
For the rear widths, remember that the pin lengths are shorter on the t4 '14, so there will be some small variance, when measured. I suppose you could measure at the center of the rear pin, which I didn't do, but using math we should have 41.65mm at the center.
Edit: I just measured to the outside of the pins with calipers, and subtracted 3mm to get center of pin.
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
Old 11-11-2013, 10:14 AM   #621
Skiddins
the t4 rear outer hinge pin to the outer hinge pin with 3degrees is 149mm,to the outside edge of the hexs its 170mm
the rear inner pins are 45mm center to center
the 14 rear outer pins are 151 with .5 out each side
hex to hex is 168
and the center pins are 47mm again with .5 out
bottom shock mount measuered on inner edge of 3mm socket is, t4 120.5 14 121.5mm
Old 11-11-2013, 11:23 AM   #622
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Orange Color Belt Tensioner
Old 11-11-2013, 11:31 AM   #623
Skiddins's Avatar
OK, front is 46.3mm measured at the first 1mm shim on the pivot pin (can't be bothered to dismantle it all) with kit settings.
I make the RF 40.5mm measured the same way (can't get at the rear pins but if the toe is the same we can assume the measurement is consistent with having shorter pins etc)
So this tells us the T4'14 front is 1mm wider at the inner pivot pins than the old car.
While the rear is 0.5mm wider than the old car.
All the above is assuming kit settings on the old, and new, car.
Can someone please check I've gotten this correct.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 11-11-2013, 11:36 AM   #624
erchn's Avatar
Looks right to me.
Old 11-11-2013, 05:47 PM   #625
Thank you
Old 11-12-2013, 06:41 AM   #626
Bishop's Avatar
How many guys actually sand and/or glue the carbon edges?, never really done it before, but I know from past cars sharp edges do tend to chip, where as rounded off a little may stop that happening, as may the glue, though it just always seems like too much work to me.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-12-2013, 06:59 AM   #627
oeoeo327's Avatar
Trader Rating: 70 (100%+)
I sand the edges lightly (600 grit sandpaper), clean the remaining dust with rubbing alcohol, let the edges dry, and treat the edges with blue loctite (applied with a cotton swab). I also use the loctite on the unfinished countersunk holes to prevent splintering. Total time invested is roughly 15 minutes for all of the carbon found in your typical TC kit. Many people go the extra mile and polish the edges, but I generally don't find that level of detail necessary.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 11-12-2013, 09:28 AM   #628
Default Yokomo Blue
Hi
Can you tell me witch XRAY T4 springs similar to the Yokomo blue spring in hardness and characteristic?
At my local track many guys use the Yokomo blue all around for LRP CPX
Thank you!
KZsolt
KZsolt36 is offline   Reply With Quote
Old 11-12-2013, 09:49 AM   #629
imprsme's Avatar
Trader Rating: 70 (99%+)
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
I follow this.
It took me all of about 45 minutes. I started with 180 grit emery cloth. Made two good passes over the chassis. Washed off carbon dust dried and Glued With Loc-Tite brand glue. Once dry I did just a quick wet sand of the glue with 600 grit. I actually did that holding the chassis over the sink.
One trick I have always done is to before glueing...take a black Sharpie and go around the edge and the screw holes. Once the Glue dries and is sanded. The black sharpie makes the edge a good looking glossy Black paint look.
I would suggest taking the time to do the chassis prep.
imprsme is offline   Reply With Quote
Old 11-12-2013, 10:09 AM   #630
Trader Rating: 13 (100%+)
I used to do all the sanding, buffing and polishing to a high shine to the chassis edges and shock towers. Now I don't. Basically a waste of time. The only one who really notices, or even cares frankly, is you.
I now just lightly sand, and put a thin coat of CA and call it good.
Sean B. is offline   Reply With Quote
SEO by vBSEO 3.5.0
