Old 11-02-2013, 04:48 PM   #586
chasingthepack's Avatar
Originally Posted by millbank View Post
Got my rear under control. Amazing set up that actually worked this friday ;-)
It was.
2k diff, 400 front shox 450 rear, 4 hole piston, 2.5-2.8 springs front, 2.7 rear. Anti roll bars 4 front, 3 rear. 2mm shim under steering block arm. 1mm shim top of c hub. 1mm shim front roll centre, 4mm shim rear hub, nothing on rear roll center. 0.5 toe out front. 3 rear. Front roll center upper clamp hole 2 rear hole 1. Front and rear shock mount hole 2. 1.5 camber front 2 rear. I think that is it.
was that newbury? where did you have the arm mounts?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-02-2013, 05:24 PM   #587
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Well I compared my 13 pin location to my 14 "center" location . and noticed the front track width is 1mm wider on 14 has anyone tried [.5•] [•.5] in front ? Now this is kit setting I'm comparing .
Also on a side note I tried installing "14" hinge pin mounts on T4 . ... Well I will say the ff & rr will bolt up to T4 with only pin length mod (-2mm) the hole location on fr wider on "14" and will not mount up on T4.
So i will be purchasing a chassis to complete the conversion im thinking
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-03-2013, 01:44 AM   #588
millbank's Avatar
Not Newbury. Frome
Not sure what you mean?
Lower pivot blocks 0 all round. Upper camber links front in hole 2 and rear hole 1
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 11-03-2013, 11:21 AM   #589
RobS's Avatar
Got my cars Friday night and built them both yesterday. Builds were awesome! Only problem I had was on one of the kits 3 out of the 4 wheel hex's wouldn't stay on the car. With the screw as tight as I could get it without stripping out the head they still fell off. Not a big deal really as I had extra's anyways but odd none the less. Can't wait to try these bad boys out!
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 11-03-2013, 11:45 AM   #590
BardSmith's Avatar
Trader Rating: 58 (98%+)
Hey guys, I'm in the market for T4 2014. Anyone have one for sale?
"Bard"
On-Road Only!
BardSmith is online now   Reply With Quote
Old 11-03-2013, 01:23 PM   #591
Trader Rating: 13 (100%+)
A main has them in stock
Sean B. is offline   Reply With Quote
Old 11-03-2013, 02:41 PM   #592
reg
Has anyone had any problems with how the motor is mounted,looks like a lot of strain put on the motor,might be just from not being used to seeing them mounted like it
reg is offline   Reply With Quote
Old 11-03-2013, 03:07 PM   #593
Brad, I thought you are a serpent guy? What happened?
X-ray T4'16 stock TC, Xray T4'15 mod sedan, Xray xb4. Xray, Motiv, Team debit card.
Boostinswifty38 is offline   Reply With Quote
Old 11-03-2013, 04:57 PM   #594
Get some ProTek M2x5mm socket head cap screws from Amain. Should fix you right up.
-Mike
Old 11-04-2013, 12:54 AM   #595
Bishop's Avatar
The TOP Photon also did the same, which I ran for two odd years and never had an issue with it, and none with the original T4 either, though I did have the mounts slip once and loose mesh/drive, but I did take a fair hit from memory.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-04-2013, 11:46 AM   #596
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Just picked up number 2 this weekend, last one the lhs had. Little over kill for vta but what the Hell
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 11-05-2013, 05:20 AM   #597
had a blast last friday,my first time on carpet in 11 years and i loved how much grip there is,i did have a few issues which slowly got sorted through the night which is why im down in the d final,the car was still loose on corner entry at the slower turns which was fairly easy to put up with,so im going to try hagbergs sorex carpet set up and see how that goes next friday,in the vid im alot faster than the guys around me but i kept making small but costly mistakes,i was slightly overgeared which when sorted should help the lap times
http://www.youtube.com/watch?v=RnttL5CE-qc
ill post a responce to the set up next week for anyone interested
Old 11-05-2013, 07:20 AM   #598
It's the small mistakes that seperate the A to where u were,
I watched that video was u the orange car?
That didn't look like a hagberg performance so not much point in putting he's setup on ur car.
Everyone complained t4 was safe xray released the 14 I drives around on its nose, the worlds best drive there car around on its nose.
Start with 1 change at a time and feel its difference. Last Friday I helped set up a 14 then drove it in round 3 it was really good.
4 things were changed from kit setup to calm the rear down.
Jampot is offline   Reply With Quote
Old 11-05-2013, 10:32 AM   #599
Has anyone flipped the servo mount over,180 deg,with servo on the right,to run with shorty packs...? How did car behave...? I know caution needs to be exercised when countersinking the other side of plate...
Thanks ...kirt
"well the marshall didn't put it on it's lid"
RB6...Orion R10
TLR 22sct...Orion R10
AE tc6.1...Orion R10
brwn bggr is offline   Reply With Quote
Old 11-05-2013, 10:38 AM   #600
I have one on the way...to run in vta as well...in a way,it makes even more sense to run a high end chassis in this class...one of the few "allowances" in the class...given restrictions on most everything else...and besides...no kill like an overkill...!
RB6...Orion R10
SEO by vBSEO 3.5.0
