Old 10-30-2013, 08:49 PM   #571
Originally Posted by King of B Main View Post
You can try so many things to get the car to dive in better into the corner but you will usually lose some middle turning. Try anything !
1)Softer Spring in front
3)lower your shock position in front
8)Go to 6 degree castors
Those would all reduce initial turn-in to get more mid-corner grip, wouldn't they? That's been my experience with those changes on other chassis.
-Mike
Old 10-30-2013, 11:33 PM   #572
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
-Mike
They should all give you initial steering.
King of B Main is offline   Reply With Quote
Old 10-30-2013, 11:38 PM   #573
rosko's Avatar
-Mike
+1
rosko is offline   Reply With Quote
Old 10-31-2013, 03:35 AM   #574
6 degree castor definitely takes away initial steering.
Smartypants is offline   Reply With Quote
Old 10-31-2013, 07:49 AM   #575
porsche928gs's Avatar
Originally Posted by Racing4Evo View Post
+1
But I would never take out screws on carpet, that's counter productive.
The change you're looking for is raising the outside front and rear camber link. That will give you entry steering as well as a lighter rear diff oil.
To this I may add thicker front shock oil for example 400cst front, 350cst rear.
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 10-31-2013, 11:54 AM   #576
chasingthepack's Avatar
Originally Posted by Skiddins View Post
The blinky class is now 17.5 and race fee's are 8, both changed a couple of weeks ago.
Skiddins
cheers,see you there tomorrow
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-31-2013, 11:56 AM   #577
Andrew S is offline   Reply With Quote
Old 11-01-2013, 04:51 AM   #578
Damian,does anyone use tyre warmers?will there be any 12v power surplus, cheers again
Old 11-01-2013, 05:50 AM   #579
Skiddins's Avatar
Sometimes people use tyre warmers, but as we get a minute or so or warm up laps it usually isn't necessary.
No 12V, but there is mains.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-01-2013, 10:51 AM   #580
Send a message via AIM to Matt W
Default A-Plus spool outdrives
Hi,
I see that A-Plus now do some delrin spool outdrives. Im guessing these will wear less and be stronger the std plastic ones?
Matt W is offline   Reply With Quote
Old 11-01-2013, 12:24 PM   #581
cwoods34's Avatar
Originally Posted by Matt W View Post
Hi,
Two tricks with the stock spool outdrives....
1. Cut any excess axle off past the wheel nut (threaded part). This can catch on boards and causes a lot of damage.
2. Tighten the outdrive screw just enough to remove lateral play in the outdrive. The moment you begin to overtighten the screw it causes extra stress on the plastic and makes it more prone to snapping.
I thought about trying delrin outdrives and axle blades.... If I do pick some up I'll comment on the durability, although XRAY plastic is hard to beat!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-01-2013, 02:39 PM   #582
ok thanks, i've never actually broken one, I just find they wear quite a lot internally creating slop!
Old 11-02-2013, 03:21 AM   #583
Skiddins's Avatar
I would also add that if you're paranoid, you can wrap a thin strip of cell tape around the outside of the outdrive. This allows the outdrive to distort slightly in an impact, but the tape helps spread the forces and prevent it from snapping out at one point;
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-02-2013, 10:08 AM   #584
pcar951's Avatar
Trader Rating: 19 (100%+)
I've found that a small amount of Hudy black grease on the drive shaft pins or in the drive cup slots, helps to reduce wear. Doesn't seem to affect the plastic.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 11-02-2013, 02:36 PM   #585
millbank's Avatar
Got my rear under control. Amazing set up that actually worked this friday ;-)
It was.
2k diff, 400 front shox 450 rear, 4 hole piston, 2.5-2.8 springs front, 2.7 rear. Anti roll bars 4 front, 3 rear. 2mm shim under steering block arm. 1mm shim top of c hub. 1mm shim front roll centre, 4mm shim rear hub, nothing on rear roll center. 0.5 toe out front. 3 rear. Front roll center upper clamp hole 2 rear hole 1. Front and rear shock mount hole 2. 1.5 camber front 2 rear. I think that is it.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
