Like Tree1Likes
Xray T4'14
Old 10-30-2013, 09:28 AM
  #556
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by jlfx car audio
My first thoughts of the 14 with one race day on it with a 90% kit setup
I changed rear toe to 2° and raised role center
[1°][°1]RR blocks
[ i ][ i ]FR blocks
Stood up rear shocks 1 hole
2000cst ae rear diff oil
Front gear diff 2.5m
1.5mm f/2.5mm r over ride height
5.2f/5.4r height
Car drives /turns great tho dont turn in as hard as i want it to .
Drags both sides of chassis BAD (high traction 2010 iic carpet) !
What would u do ?
not worry about the carpet drag. its not going to slow you down unless the hole chassis is dragging.
EA
EAMotorsports is offline
Old 10-30-2013, 09:52 AM
  #557
Skiddins's Avatar
[1°][°1]RR blocks
[ i ][ i ]FR blocks
5.2f/5.4r height
What would u do ?
What bodyshell?
If the car is very stable, try a more aggressive body.
Skiddins is offline
Old 10-30-2013, 09:55 AM
  #558
artwork's Avatar
Trader Rating: 88 (100%+)
[1°][°1]RR blocks
[ i ][ i ]FR blocks
5.2f/5.4r height
What would u do ?
Drag is good...that is how I know my car is working. I look forward to cleaning my chassis off. Of course there is a limit to that statement, but if you are dragging a few millimeters on each side your good to go!
artwork is offline
Old 10-30-2013, 10:22 AM
  #559
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
I run the P-37 LW body . what setup change would u do to increase turn in 10-15%?
jlfx car audio is offline
Old 10-30-2013, 10:28 AM
  #560
Trader Rating: 24 (100%+)
add 1mm of ackerman shims should give u something close to that. give it a try
gocoogs is offline
Old 10-30-2013, 11:09 AM
  #561
chasingthepack's Avatar
Originally Posted by Skiddins
What bodyshell?
what do you use at newbury?
chasingthepack is offline
Old 10-30-2013, 11:34 AM
  #562
Skiddins's Avatar
Testing everything at the moment, but Speed 6 is the most common.
Skiddins is offline
Old 10-30-2013, 12:40 PM
  #563
cheers,one other thing,which class of blinky do they run at newbury? and how much is the entry fee?
ive looked on their website but can only see 13.5 for blinky?just want confirmation, no race fees are listed
Old 10-30-2013, 12:52 PM
  #564
Try a Ltcr lightweight.
Al Sodano is offline
Old 10-30-2013, 04:17 PM
  #565
Trader Rating: 40 (100%+)
[1°][°1]RR blocks
[ i ][ i ]FR blocks
5.2f/5.4r height
What would u do ?
Try running anti dive in the front. I always run it.
King of B Main is offline
Old 10-30-2013, 04:20 PM
  #566
[1°][°1]RR blocks
[ i ][ i ]FR blocks
5.2f/5.4r height
What would u do ?
I also like to take 2 screws out from the top deck in the front of car.
Old 10-30-2013, 04:42 PM
  #567
Skiddins's Avatar
The blinky class is now 17.5 and race fee's are £8, both changed a couple of weeks ago.
Skiddins
Skiddins is offline
Old 10-30-2013, 05:58 PM
  #568
Forgot that I have all 4 screws removed also .
How would anti-dive give more initial steering ?
That was actually why I stood rear shocks up was so it transfered more weight to the front off power .
Old 10-30-2013, 06:42 PM
  #569
You can try so many things to get the car to dive in better into the corner but you will usually lose some middle turning. Try anything !
1)Softer Spring in front
2)Softer oil in front
3)lower your shock position in front
4)Anti -dive
5) LTC body
6)have more angle on front camberlinks.
7)make front of your car narrower
8)Go to 2 degree castors
Old 10-30-2013, 08:02 PM
  #570
Racing4Evo's Avatar
4)Anti -dive
5) LTC body
8)Go to 6 degree castors
+1
But I would never take out screws on carpet, that's counter productive.
The change you're looking for is raising the outside front and rear camber link. That will give you entry steering as well as a lighter rear diff oil.
Racing4Evo is offline
