Old 10-26-2013, 05:51 PM   #511
Jerz616's Avatar
Trader Rating: 49 (100%+)
Here are the 2 different ones. Left is '14. With it being higher on the inner link what would that do? I noticed that on the '14 the outer link in the front has a 2mm shim where the '13 has a 1mm shim. I notice this is why the outer link rubs on the inside of the wheel. So I think it was mentioned all the links are higher on the '14 in kit form. What would it do over the '13. I'm still trying to figure out the whole camber link thing. Measuring them the '14 ball is 1mm higher the the previous.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 10-26-2013, 07:12 PM   #512
porsche928gs's Avatar
Higher outer link will require more force for the car to roll this is call higher roll center on Xray setup book.
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 10-26-2013, 09:14 PM   #513
Bishop's Avatar
Got mine Friday afternoon on my way to the track, oddly I fried my motor in the first heat of the night, so spent the rest of the night building up the bulkheads and suspension mounts to see what they were like, got to say I like em.
And reports of being tail happy?, from who???, with any luck I may try mine by next weekend, got to finish the build though, being lazy this weekend...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-26-2013, 10:56 PM   #514
Team STPN's Avatar
I see lots of Carpet set ups any Asphalt set ups for meduim bite track?
Team STPN is offline   Reply With Quote
Old 10-27-2013, 01:44 AM   #515
I tried mine for the first time, it definatly was nicely planted and not tail happy!
Andrew S is offline   Reply With Quote
Old 10-27-2013, 02:04 AM   #516
Barry_Hughes's Avatar
are you running foams or rubber?
It seems to be rubber tyres on the Primafelt carpet used in the UK where the tail feels a little bit loose.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 10-27-2013, 06:22 AM   #517
I gotta say that mine is a quite a bit tail happy.
That's on very high traction carpet only on power.
Other than that I couldn't be much happier with the car so far.
If anyone finds a cure for the tailhappy behaviour I would like to hear it
Regards,
David
niemand is offline   Reply With Quote
Old 10-27-2013, 09:11 AM   #518
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
Regards,
David
I know when I had that problem with T4 I raised the inner camberlinks up in the rear and the problem went away.
King of B Main is offline   Reply With Quote
Old 10-27-2013, 10:39 AM   #519
chasingthepack's Avatar
on the 14 the inner ballstuds are 1mm taller as standard,so that must be taken into account when taking settings from the t4
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-27-2013, 12:38 PM   #520
So 3mm then?
I really liked driving the rear inner camber links higher than the front ones outdoors on the t4, so I will definately give it a try.
Also I've been thinking about going back to 1mm on the front outer camberlinks to decrease cambergain..
I'm going to report back in a few weeks when I've had time to get another training session at that high traction track.
Regards,
David
Old 10-27-2013, 12:42 PM   #521
I'm running rubber on ash felt .
Old 10-27-2013, 01:23 PM   #522
reg
So if you kept the same size washers under the ball studs that you had on the T4 what would the car do
reg is offline   Reply With Quote
Old 10-27-2013, 04:23 PM   #523
syndr0me's Avatar
Trader Rating: 32 (100%+)
Had a great weekend with the T4'14 at the Halloween Classic. The car was really good, stayed flat and performed well. I managed to finish 7th overall which isn't too bad for an old guy I guess.
Nobody had anything for the Awesomatix team, the people driving that car were about .2 per lap faster on average in 17.5. It was really quite amazing to watch.
syndr0me is offline   Reply With Quote
Old 10-27-2013, 05:05 PM   #524
Skiddins's Avatar
What sort of grip level was that on?
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-27-2013, 05:12 PM   #525
syndr0me's Avatar
.2 is a bit of an exaggeration.
I'd call the grip medium-high. It was kind of a greasy grip, the cars could move around and turned well.
SEO by vBSEO 3.5.0
