Old 10-25-2013, 01:29 AM   #496
scoyle's Avatar
On a recent post on the Xray forum Alex was recommending the use of the graphite plates and the center post as an option for low/medium grip carpet. Are there part no.s for these yet?
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 10-25-2013, 01:55 AM   #497
spencehotbodies's Avatar
Originally Posted by C.Smith View Post
Hi guys,I just finished my build and I installed electronics. I noticed a lot more
Motor noise. I double checked gear mesh and everything is good. Looking
For suggestions on what to look for?
48 or 64 dp?
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 10-25-2013, 02:47 AM   #498
RTFM all in the manual
Smartypants is offline   Reply With Quote
Old 10-25-2013, 02:53 AM   #499
Sith Lord's Avatar
Trader Rating: 21 (100%+)
http://www.teamxray.com/t4/download/...PARTS_LIST.pdf
Spare parts list shows:
302190 GRAP HITE FRONT LOWER ARM PLATE 1.6MM (2)
303190 GRAP HITE REAR LOWER ARM PLATE 1.6MM (2)
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 10-25-2013, 08:24 AM   #500
C.Smith's Avatar
Originally Posted by spencehotbodies View Post
48 or 64 dp?
48,going to change to 64
Mugen USA. Reds Racing Engines Speed World Raceway & Hobbies.KO Propo ,Matrix Tires,Colors by Chris. My wifes patience
C.Smith is offline   Reply With Quote
Old 10-25-2013, 09:02 AM   #501
Yeah 48 is quite rough.
Old 10-26-2013, 02:17 AM   #502
Anyone know the story behind the new ball studs?
-Mike
Old 10-26-2013, 05:05 AM   #503
chasingthepack's Avatar
-Mike
whats new?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-26-2013, 05:25 AM   #504
The 14 has different part numbers for inner and outer camber link ball studs. The thread on the inner ones is a touch longer, and the ball itself sits maybe .5-1mm higher. I was just wondering why they did the change.
Not sure if the steering rack and linkage balls are different. Didn't check the numbers on those.
-Mike
Old 10-26-2013, 07:51 AM   #505
Trader Rating: 13 (100%+)
I'm guessing they're optimized?
Sean B. is offline   Reply With Quote
Old 10-26-2013, 09:40 AM   #506
Send a message via AIM to Matt W
Default T4'14 very taily
Hi,
I've heard a lot of racers with the new t4 14 are having trouble with the car being very loose and taily on the rear end.
Has anyone found any solutions to this or found what is causing it?
Matt W is offline   Reply With Quote
Old 10-26-2013, 10:34 AM   #507
-Mike
well spotted,i didnt even notice,so with a 2mm shim the 14 is actually 3mm compared to the t4 which would stay at 2 mm,no wonder people ar having rear end issues with that much of a change to the links
Old 10-26-2013, 10:47 AM   #508
Why have they decided to mount the links so high compared to the t4?
Old 10-26-2013, 01:33 PM   #509
checking again against my t4 it seems that only the rear inner has changed,,i have a binding issue on the t4 that when the shocks are off,when you lift the arm it would bind on the rear inner link,this doesnt happen on the 14,but its so far on the uptravel with shock on this wouldnt affect anything,so cant see why it was changed
Old 10-26-2013, 02:23 PM   #510
Skiddins's Avatar
Having measured some old and new ball studs the difference appears to be 0.5mm
But as the studs are the same on the inside and the outside, effectively all the links are 0.5mm higher than they were.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
