Old 10-24-2013, 01:47 PM   #481
R/C Tech Elite Subscriber
I asked Alexander and it was indeed to allow the lay shaft mounts to move more making it softer.
But you'll need the option centre post also.
Ill be trying that for sure as soon as I can get the centre post.
Miniripper is offline   Reply With Quote
Old 10-24-2013, 02:35 PM   #482
porsche928gs's Avatar
Originally Posted by jlfx car audio View Post
I have a new set of spec-R 51mm joints if some one wants them I ran one pack with them in usgt in a 2012 but was barely in gauging the spool (had car +4mm track on each side for a 200mm body) so removed them and went back to stock)
$35 shipped
You need to buy the xray aluminum outdrives for the xray spool to use the spec r joints in your car without a problem. They are even lighter than the plastics ones. They come with blades to put in your axles too.
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 10-24-2013, 02:52 PM   #483
Care to explain? I've been using the Spec-R DCJs with Spec-R plastic spool cups, and haven't had any issues yet. The cups are getting some wear, but nothing I would consider abnormal.
-Mike
Old 10-24-2013, 03:03 PM   #484
I need to check what was the xray part number for them but it was an option to change the spool plastic outdrives with this aluminum ones that use plastic blades like your rear diff in that way it's less critical the reach of your axles inside the spool plastic cups.
AKA Gilberto Santos
Old 10-24-2013, 03:06 PM   #485
I had them for a long time in my box waiting to put them on when I purchase the spec r ecs axles, I put the last week and the worked great.
AKA Gilberto Santos
Old 10-24-2013, 03:14 PM   #486
Main advantage? I gives you freedom to widen or narrow your front end at the arms(not by using different thicknesses of wheel hexes).
AKA Gilberto Santos
Old 10-24-2013, 03:25 PM   #487
Xray part number #305136
AKA Gilberto Santos
Old 10-24-2013, 03:53 PM   #488
Dog Bone's Avatar
Just a suggestion, but you may want to quote the message you're responding to. It makes it much easier to understand what question you're actually answering.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 10-24-2013, 04:06 PM   #489
$35 shipped
-Mike
AKA Gilberto Santos
Old 10-24-2013, 04:18 PM   #490
There it is! Writing a book next.
AKA Gilberto Santos
Old 10-24-2013, 07:17 PM   #491
Trader Rating: 19 (100%+)
Any idea on what Diff oil for 21.5 spec class a few ppl has mentioned heavier diff oil but I can't recall anyone mentioning the weight.
Same with Shock oils too.
Any help would be appreciated.
It's for medium, flowing, asphalt track.
Cheers
bee200sx is offline   Reply With Quote
Old 10-24-2013, 07:49 PM   #492
ByteStream's Avatar
I didn't care much for the white belts .. but they do look sharp in orange.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 10-24-2013, 08:24 PM   #493
Trader Rating: 20 (100%+)
I you widen the car at the arms then maybe but I would think that would be true of any 50mm or 51mm shaft with that setup. I don't run mine wide and have been running the stock plastic cups without any issue for a long time. I did replace a set over the winter just to tighten up the front end but nothing out of the norm.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-24-2013, 09:01 PM   #494
C.Smith's Avatar
Hi guys,I just finished my build and I installed electronics. I noticed a lot more
Motor noise. I double checked gear mesh and everything is good. Looking
For suggestions on what to look for?
Mugen USA. Reds Racing Engines Speed World Raceway & Hobbies.KO Propo ,Matrix Tires,Colors by Chris. My wifes patience
C.Smith is offline   Reply With Quote
Old 10-25-2013, 01:27 AM   #495
Skiddins's Avatar
When I did that, lots of people were not impressed
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
