Old 10-23-2013, 08:59 PM   #466
Bishop's Avatar
Looks like I'll have mine by the weekend with any luck, gives me a nice project for the weekend... :-)
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-23-2013, 11:40 PM   #467
Mikkel_R's Avatar
Originally Posted by bertrandsv87 View Post
Track width does not look set.....
Not sure what you mean, what are you looking at to tell that?
Well im pleased to say the car went really well and for me with the kit setting is a far better starting point than it was on the T4 '13.
The rear of the car is a lot more stable for my driving style on the T4 '14.
The only thing I changed was to run 2.6 springs all round which made it slightly better. Next I want to try 450 in all the shocks which
ill try next week.
Mikkel_R is offline   Reply With Quote
Old 10-24-2013, 03:23 AM   #468
Send a message via AIM to Matt W
Default cso double jointed driveshafts!!
Hi, I noticed that cso do some double jointed driveshafts for the t3/t4 although they are 46mm, is this right as they seem far to short?
CSO CSO-20196 XRay T4 Double cardan joint 46mm drive shaft pair
http://demonpowerproducts.co.uk/images/CSO-20196.JPG
Matt W is offline   Reply With Quote
Old 10-24-2013, 03:46 AM   #469
daleburr's Avatar
The measurement point is different. I think 46mm is about the same as an Xray 52mm. Although since they're made by CSO you can probably just chuck them straight in the bin and not have to worry about the length.
Roche do some nice looking ones at a decent price, but they've not been out long so not heard any reports about them yet.
And in general the Spec-R ones seem to be good, although they require a narrower bearing which is never good for bearing life on the front end.
Team Xray
Old 10-24-2013, 04:03 AM   #470
Are the cso ones really that badly made? I think they use the thinner bearing as well although I race 17.5 blinky so don't go that fast!
Old 10-24-2013, 04:45 AM   #471
Skiddins's Avatar
If you can stomach the import duty, these would be better from Reflex Racing (bottom of the page);
http://www.reflexracing.net/XRAY-T3T..._c_98-6-0.html
'Wide Axle' versions are 52mm, 'Narrow Axle' are 51mm and use narrower bearings.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 10-24-2013, 05:07 AM   #472
I will buy the xray ones when I get the new car, its just some to pass the time as my old xray ones are two years old and have a lot of slop.
How are you finding the new car, a lot of people seem to be struggling to find a setup that works?
Old 10-24-2013, 06:29 AM   #473
Trader Rating: 20 (100%+)
I've been running the Spec-R versions since last spring in Mod TC outdoor and 17.5 over the winter indoor. Although they are getting a bit sloppy they have held up wonderfully with many good crashes under their belt. These are about 51mm and do use the narrower inner bearings. I also do find that I need to replace those occasionally but it's not been a big worry.
I did have a set of the xray shafts. Those made it one indoor season and about four laps outdoor before one gave up at the joint. It's a limited test but for my money I'll be using the Spec-R shafts for a long time.
I've never used any of the others so I can't compare.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-24-2013, 06:38 AM   #474
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I have a new set of spec-R 51mm joints if some one wants them I ran one pack with them in usgt in a 2012 but was barely in gauging the spool (had car +4mm track on each side for a 200mm body) so removed them and went back to stock)
$35 shipped
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-24-2013, 06:59 AM   #475
rosko's Avatar
I see hagberg raised his topdeck 1 mm , whats the effect or purpose of this?
rosko is offline   Reply With Quote
Old 10-24-2013, 07:25 AM   #476
Essnowyt's Avatar
Send a message via AIM to Essnowyt
I was wondering the same.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 10-24-2013, 08:03 AM   #477
Skiddins's Avatar
Where did you see that?
Any photos?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-24-2013, 08:40 AM   #478
Any photos?
It mentioned it on his icc setup sheet!!
Old 10-24-2013, 09:18 AM   #479
Khador12's Avatar
Hagberg did not have any screws in the top deck by the lay shift. Maybe the 1 mm spacing of the top deck allowed for better flex around the top deck.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 10-24-2013, 09:21 AM   #480
U beat me 2 it ! That's what I think also
Justin & Matt Lyons
a800s sanwa m12s
