Old 10-21-2013, 10:51 AM   #421
Skiddins's Avatar
Since changing to the T4 I've improved my track records at every track I've been to and this year managed to win my Clubs championship TQ'ing every round.
It's easily been the best car I've owned and I'm sure, when outside next year (weather is bound to ruin almost any chance before then) it will be great.
I just need to sort this lower grip carpet 'issue' and it will be fine.
Skiddins
P.S. Never really had any issue with the rear of the T4, are you sure you're not using too much steering lock etc and making it 'hook'
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 10-21-2013, 11:02 AM   #422
Mikkel_R's Avatar
Skiddins
No not to much lock.
I think i raced you in the B final at Bedworth this year. Were you car 2 on the grid? If so I was Car 3.
Mikkel_R is offline   Reply With Quote
Old 10-21-2013, 11:03 AM   #423
rack's Avatar
Trader Rating: 64 (100%+)
Originally Posted by syndr0me View Post
This isn't my idea, so I take no credit for it. But here's what's working fantastically well for me on the '14.
Use the ramp weight in the middle of the chassis, it spaces the battery out slightly more than the plastic nuts and gives a bit more clearance for the motor. Then, put the pinion on backwards. You can do this now that the motor screws are inset and don't interfere. Then, you can gain perfect access to the pinion grub screw through the cutout in the bottom of the chassis for the spur gear, not the hole they provide for the pinion screw. Also, I run my spur gear offset toward the motor side, which is different than the manual.
thanks I will try that . the other statement about it's the motor. I used the same motor on the T3 12 with no problem, but this sounds like it may work.
rack is offline   Reply With Quote
Old 10-21-2013, 11:14 AM   #424
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Default missing hex, and stripped hex
anyone else as lucky as me?
Missing hex in the head
Stripped hex when trying to tighten
First xray kit i've built that wasnt 100%
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-21-2013, 11:49 AM   #425
Jerz616's Avatar
Trader Rating: 49 (100%+)
Its a known issue and I'm sure they will mdke it right. I had 2 hex's strip. One I just used an old screw and it fixed it. The other was a bad hole in the hex. Better then I have seen on some other brands having bad parts.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 10-21-2013, 12:37 PM   #426
Trader Rating: 38 (100%+)
I had same issues, RC America hooked me up. Thanks RC.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 10-21-2013, 12:41 PM   #427
patorz31's Avatar
I was missing hexs on some ball links, and I had a hex with no hole drilled in the back part where the threads should be.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 10-21-2013, 12:42 PM   #428
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Look for the last baggie of parts. There should be another bag of "extra" screws and bits... Mine had an extra of this 1.5mm screw.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 10-21-2013, 12:52 PM   #429
R3VoLuTiOn's Avatar
Snowy.
Weird, mine didn't.
It's all good, Paul is sending me replacements!
Kinda glad to hear I wasn't the only one
Old 10-21-2013, 01:56 PM   #430
Weird, mine didn't.
John, I think it might be the screws. I thought I stripped a hex, but when I found some old m2x5 screws in my box of random stuff, they tightened up just fine. Your car and my car were from the same batch. I guess Kody didn't pass on the message to be careful with the hexes.
What class are you going to run yours in? I can give you the setup I ran on Saturday, so you know what not to do. :P
Question for everyone: has anyone noticed that two of their shock bodies have an ever so slightly thicker (or thinner, depending on how you look at it) shoulder at the bottom of the cap threads? Both my '13 and '14 had two shocks with a slightly thicker shoulder.
-Mike
Old 10-21-2013, 02:18 PM   #431
ByteStream's Avatar
Use these for the Wheel Hexes ..
http://www.amainhobbies.com/product_...-Cap-Screws-10
They fit perfect and are much better.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 10-21-2013, 02:21 PM   #432
R3VoLuTiOn's Avatar
-Mike
Mod.
I use Paul's setups almost always, never let me down. If I want to drive maniac aggressively, then Hagbergs usually does the trick.
Old 10-21-2013, 03:36 PM   #433
Bar
Skiddins
yeah, no matter what I did the car just seemed to push mid corner and the rear would break away quite viciously at times. You had a really good year with the T4 mate, and it always looked planted, my brother also had a really good year with his T4, as of course did Zak. I was actually pretty happy with my car at WLRC round of the clubmans. I am no way slagging the T4 off, but for me and especially at my home track the T3 2011 is a lot quicker, it just has more rear end grip, it doesn't push mid corner and has the worlds most amount of steering even with the locks turned down.
Luke Burr
Bar is offline   Reply With Quote
Old 10-21-2013, 06:37 PM   #434
GMartinez's Avatar
Trader Rating: 85 (100%+)
Got to see the new T4 up close car looks really good
Decisions decisions
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 10-21-2013, 07:25 PM   #435
Trader Rating: 57 (100%+)
Whats a general FDR for blinky 10.5?
PROMODVETTE is offline   Reply With Quote
