Old 10-20-2013, 04:59 PM   #391
chiefj48's Avatar
Can some post the links for advanced set up sheets, or at least what the top drivers sheet are??
thanks in advance.....
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, RocheUSA, SerpentUSA, AwesomatixUSA, ValkariaRC, Trinity, DiscountRCStore, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 10-20-2013, 05:00 PM   #392
Odin544's Avatar
Trader Rating: 93 (100%+)
Go to the xray site or petitrc.
TriCitiesRC.com
Old 10-20-2013, 05:05 PM   #393
B00t13g's Avatar
R/C Tech Elite Subscriber
To anyone running a 5.0, what's your gearing?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 10-20-2013, 08:06 PM   #394
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
We (my 12yr and I ) ran his 14 today . started with kit setup on high bite carpet (thunder Rc) .
Ended up using 1mm up and in on RR mount /1mm up in RF. And stood rear shocks up one hole. Aslo was running 2.5mil in front diff. This worked pretty good very happy with car
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-20-2013, 09:36 PM   #395
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Default new car
Ran the new car yesterday at Tamiya race track.
For me the new car is definately more stable, carries alot more corner and the steering is just smoother. It comes in turns better and out better !! I was right on pace with everyone on my first run on the car.
Great Job Mr. Hudy !!
King of B Main is offline   Reply With Quote
Old 10-21-2013, 03:06 AM   #396
Skiddins's Avatar
I ran on a mid/large sized carpet track today (10 rolls wide) and found I had problems right from the off with grip.
The carpet was new but the Schumachers seemed to have plenty of grip.
I started with this setup;
http://www.piez0r.com/Skiddins/Xray%...)-18-10-13.pdf
This setup used on Friday;
+ YouTube Video
And eventually ended up with this;
http://www.piez0r.com/Skiddins/Xray%...C-20-10-13.pdf
This was the result;
+ YouTube Video
Although at first the cars don't look massively different at each meeting, the 1st video the car was predictable and easy to drive, in the second you can see the rear of the car trying to step out etc during some of the more sweeping corners.
First thing the car was terrible, and only got slightly better. Luckily I made the A final, through consistency, not outright speed. But I couldn't push hard the way I'd have liked.
Some were suggesting that there was actually too much grip and this was unbalancing the cars. But there was very little wear on the tyres, and no tyre 'dust' on the inside of the bodyshell so we know that's not true. (After 8 runs the tyres still have the 'seam' from the mould around the middle.
I tried making the chassis very flexible by removing layshaft screws etc and loosening the motor mount nut. but this didn't work.
Tried raising the rear link at both ends and this made it worse.
Should I try to make the chassis stiff and run soft springs etc.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-21-2013, 04:30 AM   #397
over rotation into corner?
Smartypants is offline   Reply With Quote
Old 10-21-2013, 05:18 AM   #398
Skiddins's Avatar
Seems to be more mid-corner I think.
If I can just find the best way to lock the rear down, I can then start to add more steering and speed up transitions etc.
Zak Finlay said he found the same at EWS, car on edge while the MI5's had better traction.
So there's something we're missing from the T4'14 setup that the Mi5 has.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-21-2013, 05:46 AM   #399
Mikkel_R's Avatar
Skiddins
Not liking the sound of your experience with the new car as what problems you are mentioning are the exact same issues I have with the T4. When I heard that the new car had more steering than the old car I was a little worried as I never struggled with steering just rear grip break away.
Last year that's all I was chasing was rear grip. Like you said id like to be able to nail the rear down then slowly tune it out. I never had this problem with the T3 12. Must be my driving style as all the top lads get on well with the car. Zaks car at Bedworth looked amazing.
Mikkel_R is offline   Reply With Quote
Old 10-21-2013, 06:07 AM   #400
Skiddins
Yes EWS runners were having similar problems, From the cars i saw they were running longer links than your setup, did you try that?
Old 10-21-2013, 06:24 AM   #401
millbank's Avatar
First time out with the 14 and stuggled a bit for rear grip on corner entry. Laid the shocks down 2 holes and transformed the car completley. Qualified 4th in the b final but was on Afinal pace in the 1st leg of our finals. Finshed 2nd in the first leg and pushed 1stplace for about 10 laps then made a couple if small mistakes and the lead car pulled away. Second final car seemed to be very unpredictable and thought something was wrong. Turned out the steering linkage came loose. That will teach me to build a car in 4.5 hrs and then race it the next day lol.
All in all very happy with the car. Just need to use it more now to get used to having a car that does what i want it to do when i want it to do it.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 10-21-2013, 06:41 AM   #402
Skiddins's Avatar
No, one of the few things I din't try, on my list for next time.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-21-2013, 06:43 AM   #403
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
First run with the '14 was solid. I have ya beat. I brought the car to the track, while announcing the racing, a group of people built my car. First tire on the track, was the 3rd q warm up lap. The car felt VERY much like the T4, but had more mid corner. Looking forward to getting the setup down. lot's of potential here...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-21-2013, 07:41 AM   #404
hanulec's Avatar
Trader Rating: 27 (100%+)
More rear toe
Thicker rear diff fluid.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-21-2013, 07:43 AM   #405
Skiddens; I ran on low traction carpet many time with the T4 . and find that 2k in rear and 1mil In front diffs work really well on those surfaces.
Also lots of droop , like 3mm over ride in front/4.5mm in rear (measured from ride height to point which tire barely touched board.
Justin & Matt Lyons
a800s sanwa m12s
