Like Tree1Likes
Xray T4'14
Old 10-19-2013, 11:41 AM
  #376
syndr0me's Avatar
Trader Rating: 32 (100%+)
So far, the '14 feels a lot like a T4, though easier to drive and more stable. Not sure it's going to change anybody's life with its mid-corner steering, but it's better.
syndr0me is offline
Old 10-19-2013, 12:11 PM
  #377
Originally Posted by syndr0me
You probably tightened the ball ends too much on the shock shaft. Try backing it off a little bit, but make sure your shocks are the same length when you do.
+1 I had the same issue, and it was this.
-Mike
grippgoat is offline
Old 10-19-2013, 01:52 PM
  #378
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
I built all mine to 9.5mm of shaft without binding. Tried 9mm but it was to tight and bound ball up.
jlfx car audio is offline
Old 10-19-2013, 02:50 PM
  #379
AL1983's Avatar
Post Chassis Length!
Hi,
Need help.
What length is the Xray T4'14 chassis, width is 89mm. On the teamxray website it says 372mm is this measured with the bumper attached?
What is only the chassis length without lower bumper holder and bumper in mm.
I ordered a kit and am trying to have them make a chassis protector for me.
Thx for replying!
AL1983 is offline
Old 10-19-2013, 03:12 PM
  #380
Skiddins's Avatar
Originally Posted by AL1983
Hi,
Need help.
Thx for replying!
Same length as the T2, T3 and T4, around 326.5mm
Skiddins is offline
Old 10-19-2013, 04:46 PM
  #381
Penz316's Avatar
Here mine (the Ballistic is the spec motor at my club)
The orange screwz are Hiro Seiko alum/titanium kit for XRAY.
Penz316 is offline
Old 10-19-2013, 06:57 PM
  #382
B00t13g's Avatar
9.2mm is what has been suggested.
B00t13g is offline
Old 10-19-2013, 10:10 PM
  #383
Finished building the car at the track.
Ran it....
AWESOME!!!! Thanks Martin and company.
Al Sodano is offline
Old 10-20-2013, 02:39 AM
  #384
Had kind of a rough first outing. Running mod on med-high grip carpet. Started with basically kit setup but medium links, 3x1.1 pistons, 2.5M gear diff in front, and 5.5f/4.5r droop. Car was ok in Q1, about .3 sec off the fast guys, pretty consistent after getting used to the car. But it lacked on-power steering, so I took out .5mm droop in front. But that made the car way too aggressive, and the front end would hook weird when on power mid corner. So I threw a hail mary, and put 2.7 springs on the front, layed them down a hole, put the droop back, and switched tires. Car sucked in the main. :/ I think I'll just go back to 100% kit next time and go from there.
-Mike
Old 10-20-2013, 07:21 AM
  #385
Why didn't u start with kit to begin with?
Old 10-20-2013, 12:50 PM
  #386
Ran mine twice this week.
Very pleased. Ticks all the boxes. Only really laid the rear shocks down fully. Got a epic set up for my orca that works a treat!
I just need to get back on the pace.
Miniripper is offline
Old 10-20-2013, 01:09 PM
  #387
On the setup sheets the shim behind the front shock. Are they referring to the top and bottom of the shock.
losi888 is offline
Old 10-20-2013, 01:43 PM
  #388
Top....
Old 10-20-2013, 02:34 PM
  #389
I wish I knew.
-Mike
Old 10-20-2013, 02:35 PM
  #390
Khador12's Avatar
On page 26 of the manual it shows top and bottom.
Khador12 is offline
