Old 10-19-2013, 12:14 AM   #361
Clint161's Avatar
Originally Posted by Jerz616 View Post
Here's a picture of my 1251 servo 90* to the chassis. Its dead on with no sub trim at 90*. With full travel I get 25* in each direction and each side is balanced within 7% of each other on my KO radio. So it can be done the way the book shows and have even travel both directions.
The travel on the 1251 must not be consistant from servo to servo, I do my setup exaclty like Skiddins does and I also tried the 90* system and I get equal travel on my set up stations with a 4PK at 120% and my Savox is nowhere near full travel. My Futaba gets full travel easily. I have seen here a few guys with Savox are getting full travel so I have to believe that different Savox servos must have different travels. There is no way you could get full travel with the amount of degrees my Savox servo will move.
Clint161 is offline   Reply With Quote
Old 10-19-2013, 12:17 AM   #362
Could also be different radios.
-Mike
Old 10-19-2013, 12:18 AM   #363
Clint161's Avatar
-Mike
Hmmm... good call.
Old 10-19-2013, 12:33 AM   #364
Jerz616's Avatar
Trader Rating: 49 (100%+)
-Mike
Very true. I don't even know all the stuff on my KO but I only use the travel and balance menus. I have the travel at 150 and the balance at 87% right and 80% left. I don't know what this translates to on other radios. Maybe like it was said above that the 4pk gets 120% And that's what's causing some to not get full travel side to side. But I know all three of my cars have a 1251 or a 1258 and all are pretty much identical. So I guess the common denominator is my radio.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 10-19-2013, 01:17 AM   #365
B00t13g's Avatar
R/C Tech Elite Subscriber
I had issues with a savox servo getting full travel when I ran a 4Pksr no issues since going back to ko, I've also only run ko servos since then. I was never happy with my savox stuff.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 10-19-2013, 01:47 AM   #366
Bishop's Avatar
7% off or unequal to me seems a lot, more so if the KO is getting full travel at 80%, mine was around that with the link as per the build manual, but to me thats enough to notice a steering speed difference, I aim for dead equal or maybe 1-2%.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-19-2013, 01:56 AM   #367
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi there make sure on your servo saver the insert for your brand of servo the letter is in the middle at the top might help with the throw issue.cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 10-19-2013, 02:54 AM   #368
Mikkel_R's Avatar
Same here, 7% seems a fair bit in terms of turning circle on the track. I guess if he set the servo saver with at a slight angle ( and I mean slight) it would be just about bang on.
Mikkel_R is offline   Reply With Quote
Old 10-19-2013, 05:20 AM   #369
Skiddins's Avatar
My second time out with the car at Newbury;
+ YouTube Video
1) Chris Grainger Mi5 (White)
2) Glenn Westwood ? (White) Results say Associated, but I couldn't see any Blue ?!
3) John Zottle - BD7 (Dark Orange)
4) Me - T4'14 (Blue with yellow and orange stripes
5) Danny Vella - T4
6) Scott Booth - Mi5
7)Keiran Clift - Awesomatix
8)Nick Waywell - T4 Bright Orange
Most manufactures present which isn't bad for 8 car finals
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-19-2013, 07:01 AM   #370
Mikkel_R's Avatar
5) Danny Vella - T4
Car looks good. What setup changes have you tried from stock and what tyres are you on? Looking foward to trying mine out at the next rug racers event.
Old 10-19-2013, 07:32 AM   #371
Skiddins's Avatar
We were on Sorex 28JB's
Only changes from stock, 2k diff oil
Front shocks in one hole and no spacers
1mm on rear camber link
Removed rear two layshaft screws
Ride Subaru Body
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-19-2013, 08:59 AM   #372
rosko's Avatar
I have a m11 radio using savox low pro servo and i can easily get full lock easy, car doesnt have a lot of steering throw. Ordered rsd smaller o/d spacer should get probably a mm to 2 mm extra throw. Havent ran car yet but if i have plenty of steering stock then i probaly wont even put on the rsd spacer
rosko is offline   Reply With Quote
Old 10-19-2013, 09:13 AM   #373
Jerz616's Avatar
7% really isn't that much off. Considering 5% barely moves the servo .5*. Maybe I'm just not that picky about it. My turning circle is the sane in both directions and the speed in both directions feels the same. It could just be a tolerance issue with servo parts.
Ryan Gracey
XRAY XB8'14
Old 10-19-2013, 12:14 PM   #374
morgoth's Avatar
I'm building my shocks and the balls are very tight in the lower shock ends. Is any else having this problem? Not sure if this is supposed to be like this or if it's a manufacturing fault.
The upper balls move freely, but the lower ones bind in all 4 shocks. I positioned the shiny surface to the outside, just like the manuals tells you to do.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 10-19-2013, 12:40 PM   #375
syndr0me's Avatar
Trader Rating: 32 (100%+)
You probably tightened the ball ends too much on the shock shaft. Try backing it off a little bit, but make sure your shocks are the same length when you do.
syndr0me is offline   Reply With Quote
