Old 10-18-2013, 08:05 AM   #346
syndr0me's Avatar
Trader Rating: 32 (100%+)
Help me out here, how can I leverage the new motor mount properly? Do I still have to extend the flat spot on the shaft of trinity motors or am I missing something?
syndr0me is offline   Reply With Quote
Old 10-18-2013, 08:07 AM   #347
artwork's Avatar
Trader Rating: 55 (100%+)
Mount the pinion so that the set screw faces the battery instead of the motor...it is a little harder to tighten down but it works just fine.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-18-2013, 08:23 AM   #348
syndr0me's Avatar
Oh, that works? How come we didn't try that before? Any issues with the belt hitting the set screw on the pinion and fraying?
Old 10-18-2013, 08:25 AM   #349
artwork's Avatar
I have done it from time to time...just have to be careful to ensure you have clearance.
Old 10-18-2013, 08:48 AM   #350
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Yea the new hole in bottom is nice but still useless with titanium racing pinions... I have to still go thru top deck to tighten
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-18-2013, 08:54 AM   #351
O and BTW all went smooth with build last night no issues at all . I built to kit set up ...for now .
Have to ask tho . I'm using a orca 325g battery . what's folks doing to balance car that might not be considered normal ways of balancing the car ?
I (so far have moved the heavier items of the car out some on electronics side added a larger 35mm fan used the supplied savox screws to secure servo(nice btw) at full length has anyone successfully moved battery in any ?
Justin & Matt Lyons
a800s sanwa m12s
Old 10-18-2013, 09:22 AM   #352
Jerz616's Avatar
Trader Rating: 49 (100%+)
I am using the orca 7000 in mine along with the VX a 1251 and KO rx on the electronics side. I had to add 10g on the electronics side to balance it. I put it on the front left under the steering rack. Perfect balance and weight. I tried moving some stuff outward on the elec side but didn't like it hanging off the chassis. I was able to do that on the '13 but the chassis is narrower on the '14 so I had to go with added weight.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 10-18-2013, 12:19 PM   #353
chasingthepack's Avatar
Originally Posted by grippgoat View Post
Ok, so who skipped the chassis sanding and CA-ing? Debating whether I should go back and do that before I install electronics...
-Mike
i dont bother with all that phaffing about,i would do it if i raced on carpet as it can snag if it gets damaged from a crash,dont have that problem on tarmac so dont bother
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-18-2013, 12:26 PM   #354
you can always shim the motor so it sticks out more instead of adding weight to that side
Old 10-18-2013, 12:29 PM   #355
as above
Old 10-18-2013, 12:38 PM   #356
I have seen one person do this and I thought it was stupid ... He stripped several spurs in incidents that happen on the track . using large steel shims might allow it to work tho . but this for me would be a last option .
Justin & Matt Lyons
a800s sanwa m12s
Old 10-18-2013, 01:14 PM   #357
i dont do this currently(weight added to battery side)but have done in the past,i used 10mm diameter alu spacers from a tc6 that i filed a flatspot on,4 in total making 2mm,i crashed alot then and never had an issue,if the right hardware is used it shouldnt be a problem
Old 10-18-2013, 01:40 PM   #358
Yea a larger OD washer would be OK but still don't like the idea of setting motor out we rub a lot on our track ....
Justin & Matt Lyons
a800s sanwa m12s
Old 10-18-2013, 05:38 PM   #359
Skiddins's Avatar
Someone mentioned a shim especially designed to space a motor out, but it was mentioned that moving a heavy weight (180g) for a motor further out can effect the handling, making it more difficult to drive.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 10-18-2013, 09:01 PM   #360
Jerz616's Avatar
Here's a picture of my 1251 servo 90* to the chassis. Its dead on with no sub trim at 90*. With full travel I get 25* in each direction and each side is balanced within 7% of each other on my KO radio. So it can be done the way the book shows and have even travel both directions.
Ryan Gracey
XRAY XB8'14
